Robi not waking up properly Options
Ron
#1 Posted : 09 September 2018 16:37:30
Rank: Amateur Level 1
My Robi was working for a couple of times , but now when he wakes up from laying down all that happens is he goes to a standing position but laying down , and lots of commands are just not registering with him , do you think this could be a Main CPU board gone faulty ,any advice would be helpful Thanks Ron
#2 Posted : 09 September 2018 18:28:56
Hi Ron
Firstly welcome to the forum. Could you check for me how long it takes for Robi to charge up from him having no power please and get back to me.
Ron
#3 Posted : 19 September 2018 16:28:40
arpurchase wrote:
Hi Ron
Takes about 3/4 hour to charge , robi understands some commands bus does not go to the stand up position when you switch him on , he was working okay to start with Regards ron
#4 Posted : 19 September 2018 18:15:07
Hi Ron
Could you replace Robi's brain SD card with the one you used to test robi's arm and leg movements and get back to me with the results.
Robi should wake up as normal without having to do the wake up procedure after you put the brain SD card back into Robi.
