Issues 84 - Arms Options
LSainsbury
#1 Posted : 02 September 2018 11:19:16
Hi all,
Just put together my latest issues...
Issue 84 - the arms.
One of mine (bottom arm) seems to stick when going back in. I little press and it pops back in.
Looks like the plastic maybe catching somewhere. Anybody else had this?
It's not faulty and dosn't really warrant a replacement issue - perhaps I have something done up to tight.
The motor works fine and the arms go in and out correct - just sticks slightly...
Any ideas?
Cheers
Lee
#2 Posted : 02 September 2018 11:45:33
I would check all the linkages for that side one may be a little tight or its catching somewhere and also look at the point where is stops on the front as there may be something its catching on.
Spudtrooper37
#3 Posted : 02 September 2018 12:04:46
Hi,
My bottom arm was catching on the body as it closed, I found that the arm was loose within the pivot mount causing it to sag.
So I stuck I piece of plasticard to the underside of the pivot mount and filed the recess slightly bigger than the original.
Works a treat now, will post some pics later to show this.
Darren
LSainsbury
#4 Posted : 02 September 2018 14:53:48
Will do - cheers. The linkage looks fine...will have to have a closer look - it was quite a late build last night.
LSainsbury
#5 Posted : 02 September 2018 14:54:45
spudtrooper37 wrote:
Hi,
Sounds the same as mine. Would love to see your pics of the issue and corrective action. Thank-you! :-)
Spudtrooper37
#6 Posted : 02 September 2018 16:09:24
Hope you can see what I have done, it was to make that recess where the pin goes slightly smaller to make it a tighter fit.
Spudtrooper37 attached the following image(s):
Darren
stwood6
#7 Posted : 28 November 2018 14:59:52
Rank: Beginner Level 3
Just finished issue 84 and have the arms installed. They fit perfectly and move beautifully. But the top arm doesn't tuck back into the body - it has about 1/2 inch of play when they are fully retracted, and more often than not, it is partially open.
I see that a bumper is molded into the body to stop the linkage movement when it is closing. It looks like I could trim that back and get another couple millimeters of movement to close the arm completely.
Before I do that, though, I was wondering if anyone else has run into this, and if they had a more eligant solution that pulling out a grinder.
Current Builds: R2D2, Millenium Falcon
#8 Posted : 28 November 2018 15:05:48
Try readjusting the linkage position 1st . I found that if you have them as far back as possible to the closed position when fitting the assembly helps with the mechanism closing properly.
stwood6
#9 Posted : 28 November 2018 16:21:53
Thanks for the quick response. Did as you suggested, retightening screws with arms pushed towards the closed position and it worked perfectly!
This page was generated in 0.122 seconds.
