Paint Options
dandare
#1 Posted : 05 July 2011 08:24:23
Hi all
This is probably a question that's been asked before but does anyone know the exact colour for the McLaren, as I need to do some touch ups on the nose front wing fixing plates Confused
#2 Posted : 05 July 2011 10:13:01
First of all are you going to use a brush to do the touch up? The closest I can suggest for small areas like you mention is to use an Edding silver paint marker.. use it at the very end though as its liable to wipe off if constantly being touched by fingers..
Spencer
dandare
#3 Posted : 05 July 2011 19:03:06
Hi Warthog
Thanks for the response.
I need to airbrush in the front wing plates as I did not like the join line so done a little sanding to flush them up.
I was intending to mask and blow in from the nose cone down
#4 Posted : 05 July 2011 19:15:54
Hi Dan ( I presume its Dan?)
Then I would suggest using Alclad2 Chrome if your going to use an Airbrush.. look up some of the real pictures of the car and you will see that it shows a high chrome finish..
Here's a picture for Ref: MP4-23
dandare
#5 Posted : 06 July 2011 08:19:55
Hi Warthog
yep it is Dan
thank you very much
I will hopefully be able to blend in the nose/wing struts.
very much appreciated
BigGrin
dandare
#6 Posted : 10 September 2011 21:43:29
Hi Warthog
really sorry to bother you but im having a little trouble
i finally managed to get some Alclad 2 chrome after everyones stocks had run out.
ive painted a gloss black base as suggested, then over painted with the chrome! however the chrome finish has come out Flat?
have i missed something? do i need to finish it off with a lacquer? or do i just need to give it a polish.
really hope you can help
Austin
#7 Posted : 10 September 2011 23:49:59
Dan I think you should look at warthogs post on his build, well worth a gander.
#8 Posted : 11 September 2011 17:45:51
dandare wrote:
Hi Warthog
Hi Dan,
When using the Alclad2 Chrome you must make sure that the base coat (black gloss) is polished or give a coat of lacquer then polish it with t-cut or something similar.. Make sure you have given the bottle a good shake (at least a minute) and that your compressor is set to 15-20 psi... just lightly go over the areaa being done because if you keep it on one area and try to cover it all in one go the you will get a "frosting" effect or "matt" effect which is probably what your getting..
Hope this helps mate.. any problems just ask..
Spence
dandare
#9 Posted : 12 September 2011 08:15:39
Hi Spence
thanks for replying
will give it another go, hopefully i can get a better finish.
thank you
dan
bigmal0
#10 Posted : 15 September 2011 20:24:05
Hi
Alclad ii Chrome must be sprayed over ENAMEL and when thats dry then apply chrome lightly in 2 coats. You will find it works fine.
This page was generated in 0.370 seconds.
