Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Hi all This is probably a question that's been asked before but does anyone know the exact colour for the McLaren, as I need to do some touch ups on the nose front wing fixing plates Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
First of all are you going to use a brush to do the touch up? The closest I can suggest for small areas like you mention is to use an Edding silver paint marker.. use it at the very end though as its liable to wipe off if constantly being touched by fingers.. Spencer
Hi Warthog Thanks for the response. I need to airbrush in the front wing plates as I did not like the join line so done a little sanding to flush them up. I was intending to mask and blow in from the nose cone down Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Hi Dan ( I presume its Dan?) Then I would suggest using Alclad2 Chrome if your going to use an Airbrush.. look up some of the real pictures of the car and you will see that it shows a high chrome finish.. Here's a picture for Ref: MP4-23
Hi Warthog yep it is Dan thank you very much I will hopefully be able to blend in the nose/wing struts. very much appreciated regards Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Hi Warthog really sorry to bother you but im having a little trouble i finally managed to get some Alclad 2 chrome after everyones stocks had run out. ive painted a gloss black base as suggested, then over painted with the chrome! however the chrome finish has come out Flat? have i missed something? do i need to finish it off with a lacquer? or do i just need to give it a polish. really hope you can help Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Dan I think you should look at warthogs post on his build, well worth a gander.
dandare wrote:Hi Warthog
really hope you can help Hi Dan, When using the Alclad2 Chrome you must make sure that the base coat (black gloss) is polished or give a coat of lacquer then polish it with t-cut or something similar.. Make sure you have given the bottle a good shake (at least a minute) and that your compressor is set to 15-20 psi... just lightly go over the areaa being done because if you keep it on one area and try to cover it all in one go the you will get a "frosting" effect or "matt" effect which is probably what your getting.. Hope this helps mate.. any problems just ask.. Spence
Hi Spence thanks for replying will give it another go, hopefully i can get a better finish. thank you dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Joined: 27/07/2011 Posts: 99 Points: 293 Location: Marlow
Hi Alclad ii Chrome must be sprayed over ENAMEL and when thats dry then apply chrome lightly in 2 coats. You will find it works fine. Tony
