There is a discrepancy in the dimensions of the x wing.The advertisement says it is 20 inches long, but the downloadable promo says it is 74.4cm long which is 29 inches. 20 inches would be too short to me because my 1/24 x wing is almost 20 inches long. I know the efx x wing on which it is based is 20 inches long.Can you confirm the length of the x wing?
Its a typo that has been corrected, is indeed 29.3"  The Spec info is also being updated with this info: Landing Gear & Mounting Point: Your X-wing features landing gear that can be fitted to display your model on a shelf or table. You can also remove the landing gear and attach a mounting bracket to display the X-wing in flight mode. (A wall mount bracket will be made available to purchase via the ModelSpace online shop). Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Premium Subscription offer
Opt for the PREMIUM offer and receive exclusive 1:18 scale hangar accessories to create a detailed display of your X-wing including Luke Skywalker pilot figure that slots into the X-wing's cockpit. This exciting accessory pack is ideal for creating a detailed display of your X-wing and includes:
- PERSONNEL TRANSPORTER complete with driver figure and pilot passenger figures. - FUEL PUMP with hose and X-wing ground crewman. - CREW LADDER allowing access to X-wing droid socket, complete with technician figure. - YELLOW REFUELLING CANISTER model. - LANDING LIGHTS that really light up! - STORAGE CONTAINERS for equipment and cargo. - SPECIAL LUKE SKYWALKER pilot figure that slots into the X-wing's cockpit. (note: all figures are non-poseable and affixed to items in the set (or are designed to only fit in the X-wing cockpit, in the case of the Luke figure).
The more I see of this the more I love it..... Looking forward to seeing the builds starting.... Regards Alan
chameleon wrote:I’d rather have had the mirrored base and stand. There’s no point having movable wings and light up engines if it’s landed on a diorama. It would be easy enough to create your own mirrored base, as the X-wing features landing gear that can be fitted to display your model on a shelf or table.
 The ground crew and accessory's look the bizz Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Yes it’s a nice idea and is one gained from such as Mark Warren’s customised Falcon build here on the forum http://forum.model-space...spx?g=posts&t=25355
Just a reminder for anyone that might have the previous ‘market test’ issues 1-4., You should discard these parts as they have since been revised and may not be compatible with the ‘released’ collection build.
Not too long to wait until your first parts will be with you
Build Your Own X-wing - History and Overview with Steve Dymszo
https://m.youtube.com/wa...tu.be&v=pMfJhRBYedM
Great video. Certainly shows the model off well and some great detail which looks to be better than the original prop. Mark Regards Markwarren (Mark) Admin
 Some good details explained in the vid Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great video, packed full of interesting information on this great kit..... Regards Alan
WOW After watching this video, I think this is another kit for my list  It really brings the model to life. Steve explains just how customisable this kit could be. Yep, definitely on the ‘wanted’ list
CaptnBirdseye wrote:WOW After watching this video, I think this is another kit for my list  It really brings the model to life. Steve explains just how customisable this kit could be. Yep, definitely on the ‘wanted’ list Hope you get your wish Gray.... Regards Alan
Some interesting facts about the X-Wing movie props that were made.The X-wing was first made by Industrial Light & Magic (ILM). Joe Johnston Drew and Colin Cantwell made models that became the final X-wing fighter in Star Wars Episode IV: A New Hope. ILM also made miniatures in different sizes, with wing markings showing which prop was for each pilot. Each X-wing model was built around a hollow core to hold parts for effects such as lighting.
Besides the models, the crew made one full-size X-wing for scenes in the Rebels' Yavin IV base hangar; they used editing and cardboard cut outs to make it seem as if there are dozens of fighters. The crew also made a full-size X-wing cockpit that was used for all actors; the astromech droid behind each actor was changed for each starfighter.Regards Markwarren (Mark) Admin
The Premium accessory offer takes it to a new dimension..
- PERSONNEL TRANSPORTER complete with driver figure and pilot passenger figures. - FUEL PUMP with hose and X-wing ground crewman. - CREW LADDER allowing access to X-wing droid socket, complete with technician figure. - YELLOW REFUELLING CANISTER model. - LANDING LIGHTS that really light up! - STORAGE CONTAINERS for equipment and cargo. - SPECIAL LUKE SKYWALKER pilot figure that slots into the X-wing's cockpit. (note: all figures are non-poseable and affixed to items in the set (or are designed to only fit in the X-wing cockpit, in the case of the Luke figure).Tomick attached the following image(s):
 This is a lovely detailed model, and with the display pieces too.  I’m gonna need a bigger room Regards Markwarren (Mark) Admin
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
Markwarren wrote: This is a lovely detailed model, and with the display pieces too.  I’m gonna need a bigger room Just started the official built yesterday. Only got two words for everybody..... MUST HAVE!!!! Forum Support Team http://www.model-space.com/de/
