Thank you guys for your kind words. Mark Regards Markwarren (Mark) Admin
A little more done to the pod. The first picture shows the pod racer in the movie and how the weathering looks with scorching from the engines. This is how I wanted it to look on the diorama. I have also worked out a way to hide the rods that will hold the pod and engines in place with the wiring inside. There is still much more detail to add along with the screen, satellite dish and Anakin himself. More soon
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Looks absolutely fantastic Mark  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Stunning Mark, simply stunning.... Regards Alan
Superb work Mark Al
Looks great you want tnget in and take it for a spin “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you all for your kind comments. Mark Regards Markwarren (Mark) Admin
 Rank: Pro     Groups: Registered
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Looks just like the real think stunning work
Looking stunning Mark, well done. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Stunning work.Your weathering is absolutely perfect.its so hard to do really authentic looking weathering and you have totally nailed it.Cant wait to see the finished model.
Many thanks for your kind comments guys. Mark Regards Markwarren (Mark) Admin
The pod is almost complete. I have finished weathering with some sand colour and exhaust soot and then varnished it all with some vallejo satin varnish. The next step was to fit the windscreen in place. This was made from a piece of clear acetate, with some heat shrink tubing cut and place at the bottom of the screen to represent the rubber. This was not an easy task, I had to roll the acetate to give it a bend before I glued into place. I then weathered the glass panel slightly with sand oils to match with the rest of the model. I still have the antennas to apply, but this will be done at the final stages of the diorama, so not to damage them. I just need to finish off the engines and then onto the diorama itself.
More soon, happy modelling.
Your pod weathering looks really cool Mark
Looks stunning Mark. very well done. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great weathering Mark, superbly done.
Thank you guys for your comments and support. Mark Regards Markwarren (Mark) Admin
Just a very quick update on the diorama. I’m finishing off the actual model parts before I start to construct the diorama itself. Here, you can see the link cable between the pod and the engines. You will note the hook on one end, this is placed/attached on the end of the cable attachment fixed to the pod as shown. This not only looked ugly but was very wrong to the original, so, with a little work I have adjusted the cable accordingly to fit where is belongs. I have also had to reshape the cable parts to fit around the pods front section allowing to rest on the cable support.
More soon.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
That looks very cool. Malc.
