Staining the model at what point Options
Lord-Obsidian
#1 Posted : 30 July 2018 21:45:13
Hello all together,
I've started planking the hull and want all the colors done with stain. At points where planks change colors, this will be almost impossible if they are glued already. Has anybody done this before and got a hint for how to proceed best?
The lower hull and ribs are supposed to be in teak, yellow in yellow an the dark planks in a nut tone. The inside I would like to have in oak. So I can't stain when parts are in place because the stain soaks all neighbouring parts...
Greets
Daniel
Lord-Obsidian
#2 Posted : 30 July 2018 21:49:11
Oh and are the planks made of lime wood? I kind of need some extras BigGrin
#3 Posted : 30 July 2018 23:08:13
Hi Dan
To obtain the colour scheme purely through the use of wood stains or dyes is not going to be possible simply because you cannot control where the stain will go. Stain will soak into the wood and leach into areas you don't want it to go and masking the areas off will not work. Best way of achieving the colour scheme is through the use of acrylic paints and there is a set that has been produced specially for the Victory.....
https://www.model-space....nt-set-hms-victory.html
The wooden strips provided in the Victory kit is actually birch and not lime wood...
Lord-Obsidian
#4 Posted : 31 July 2018 06:18:34
Thanks, Alan!
I think I'll paint it differently from the original tone.
Can I use any kind of acrylic paint?
Dan
#5 Posted : 31 July 2018 08:16:49
Lord-Obsidian wrote:
Thanks, Alan!
Dan
Hi Dan,its a personal choice, you can use any kind of acrylic paint you wish but I would suggest you do some test samples first to make sure you're happy with the results. The Admiralty paints were specifically designed for model ship builds...
This page was generated in 0.138 seconds.
