6 Pages «<3456>
RAF100 build entry - Fairey Swordfish Mk1 Options
#81 Posted : 25 July 2018 07:19:33
BigGrin Coming together very nicely now, nicely doneCool
#82 Posted : 25 July 2018 18:41:45
Thanks to all who looked in. Cool Cool
So todays update:
Fixed all the front upper wing details including gun sight, tie cables etc.
Then finished the engine and fixed it into its cowling.
More coming soon. BigGrin
#83 Posted : 25 July 2018 22:30:14
Nicely done Derek, looking good....Cool Cool
#84 Posted : 26 July 2018 06:36:45
Engin looks fab, nearly done me thinks Cool
#85 Posted : 26 July 2018 07:17:04
BigGrin Looking good and nice job on the engineCool
#86 Posted : 27 July 2018 17:07:59
Thanks Alan, Jase, Andy and all who looked in. BigGrin
So the finish line is just round the final bend.Blink Blink
I`ve attached some pics of where I`m at below.
The wings are not finally fixed yet as one still needs its bracing wires and "Oh boy" are they a pain. I`ll fix the wings very near to the end as I wan`t to put the decals on the fuselage without the wings getting in the way or causing handling damage.
As you can see the torpedo and main undercarriage are also ready for final fitting, while the rear wheel and prop are in the coolest room I can find for the paint to dry.
So the to do list:
Brace wire the second wing
Decals
Bring it all together
Have a large cold beer to celebrate completion. Drool Drool Drool
#87 Posted : 27 July 2018 17:35:11
BigGrin Looking good, what are you using for rigging thread I found Ezeline works well for meCool
#88 Posted : 27 July 2018 17:54:12
Hi Andy BigGrin
I`m using the Tamiya etch set that can be seen in the link below as it has other good parts to use with this kit.
www.wheelspinmodels.co.uk/i/157180/
#89 Posted : 28 July 2018 22:52:04
Hi All BigGrin
Made a start on the decals today while waiting for some of the bracing wires on the second wing to fully set. Not a lot but a step nearer completion.Blink
#90 Posted : 29 July 2018 07:17:27
BigGrin Looks good from hereCool
#91 Posted : 29 July 2018 11:00:42
Hi looking very nice indeed ,be good to see her over the finishing line ,cheers mick .BigGrin
TRGRichie
#92 Posted : 29 July 2018 11:20:34
Nice
Rich
AUTO FRUMP STOMPER
#93 Posted : 29 July 2018 12:01:42
You’ll deserve that cold beer once she’s done, but looking good so far ThumpUp
#94 Posted : 29 July 2018 12:31:42
Looking great, she'll look superb with the wings and rigging in place.
#95 Posted : 29 July 2018 15:44:25
Thanks for the comments every one and those who looked in. I`m very grateful.Blushing Blushing
This update shows the second wing rigged and the fuselage decals completed.
I`ve still not permanately fixed the wings as decals on them to do next and then its the big coming together.Blink Blink
Then a little surprise.Flapper
#96 Posted : 29 July 2018 21:53:08
Turned my attention to detailing the prop now.
Main colour is semi gloss black with flat yellow tips. Easy enough, but then each tip has a decal to put on a thin flat red stripe.
Thing was that the decal wasn`t just the red stripe. It was clear from the tip of the prop until you got the red stripe about 1/3rd of the way down each blade of the prop. So I decided I wanted to paint the red stripes, but how to get them even and in the right place?
Here is my solution: Pics below.
Trim the decal very close to its edges.
Clamp the decal to the tip of a prop blade. It did damage the yellow paint as can be seen, but thats been repaired.
Next slide a piece of 2mm masking tape under the decal so it lines up with the red stripe on the decal.
Repeat with a second piece of masking tape for the other side of the red stripe and remove the decal.
Paint the stripe between the pieces of masking tape.
Remove the tape then repeat for the other two blades.
The final pic shows the prop installed and Tamiya were very clever at this point as they give you a piece of rubber tubing that was hidden inside the built engine and the pin of the prop holds firm in this tube allowing the prop to spin but not fall out. SIMPLES Laugh
Left to do:
Wing decals
Then bring the final bits together
#97 Posted : 29 July 2018 22:51:45
Looking impressive Derek, lovely work....Drool Drool
#98 Posted : 30 July 2018 00:08:38
Nicely done with the red stripes BigGrin end is in sight now.
#99 Posted : 30 July 2018 07:32:11
BigGrin Coming together nicelyCool
#100 Posted : 30 July 2018 07:44:58
Nice work Derek, coming together very nicely.Love
6 Pages «<3456>
