 Rank: Pro  Groups: Registered
Joined: 25/04/2011 Posts: 165 Points: 471 Location: Glossop
Hi All Can anybody post two templates of the stern curvature I need to sand down to. I am having trouble getting the correct shape. The templates could be taken over installed planking. I have drawn the approx. positions of the templates I need in the photo. Your help would be greatly appreciated because I am a novice in all this.  First Build HMS Victory and HMS Endeavour Also Krick steam boat "Victoria" Cheers Ivan (Ordinary Seaman) http://www.old-glossop.com
Firstly you need to sand the frames so they are flush with the stern post, and then start to shape the frames as per this photo
Thanks Mr T That is the area, Appologies for using your photo. This is the area I may need a template for. However your photo has given me a good idea of what to achieve.  First Build HMS Victory and HMS Endeavour Also Krick steam boat "Victoria" Cheers Ivan (Ordinary Seaman) http://www.old-glossop.com
Tomick wrote:Firstly you need to sand the frames so they are flush with the stern post, and then start to shape the frames as per this photo 7 hrs later I have managed the starb stern curvature correctly. The above quote is very important espescially to beginers like me. Thanks to Jonny and Mr T for the photos First Build HMS Victory and HMS Endeavour Also Krick steam boat "Victoria" Cheers Ivan (Ordinary Seaman) http://www.old-glossop.com
