R2-D2 microcontroller unit (MCU) Options
#1 Posted : 25 July 2018 16:43:54
Issue 94 includes the microcontroller unit (MCU) that acts as R2-D2’s ‘brain’.
It is equipped with sockets into which all his sensors, motors, displays, other electronics, and power supply will be plugged.
The MCU’s circuit board is pre-installed in a housing that will protect it from damage or electrical interference.
LSainsbury
#2 Posted : 25 July 2018 20:43:31
Thanks for the info! Do you have any better photos of the unit?
Any news on the battery we have to purchase?
#3 Posted : 25 July 2018 20:56:20
Not until the production stock arrives.
Battery info here: http://forum.model-space...amp;m=286777#post286777
An insert will be provided in Issue 92 with the battery offer.
Spudtrooper37
#4 Posted : 25 July 2018 22:49:53
I'm liking all these snippets of information (the battery and ECU) and the build diary 😍
Darren
DC-Zol.
#5 Posted : 25 July 2018 23:53:05
Rank: Amateur level 2
Hi Tomick,
Do you know if the MCU housing is completely shielded? or is it a plastic casing?
Thanks in advance 👍
#6 Posted : 26 July 2018 06:57:50
Hi Tomick,
Thanks in advance 👍
The manufacturer info states that the MCU is within a factory fitted case that protects it from damage or electrical interference, therefore is shielded.
LSainsbury
#7 Posted : 26 July 2018 21:55:09
An insert will be provided in Issue 92 with the battery offer.[/size][/color]
Perfect!!
This page was generated in 0.173 seconds.
