the marking gauge Options
pfcdre
#1 Posted : 22 July 2018 19:25:51
hi i am now on the 2nd row of gun ports and the instructions say to make a marking gauge, my concearn is even with my glasses i cant see to remove half a mm from a strip of planking, whats the best way of achieving this thanks
#2 Posted : 22 July 2018 21:55:23
I solved my vision problems by obtaining a set of optivisors, I find them invaluable....
Optivisors
To make the marking guage I sanded the edge of a strip of planking and checked the width of the strip with the use of a set of digital calipers....
Calipers
pfcdre
#3 Posted : 22 July 2018 22:59:48
thanks Alan, i used to have great eyesight but age has took its toll, anything close is just a blur lol, anyway i made the gauge as per your instructions, i have a digital caliper and it worked out nicely, i also just made a gunport template from some spare ply, when i measure with the calipers i get 11.9mm x 11.7mm do you think this would still be usable, im thinking that by the time i have drawn around it i will can a small amount[ if its exactly 12mm i would get a 12.3mm hole possibly]larger than needed
#4 Posted : 22 July 2018 23:52:33
Age has caught up with me too so know what you mean. I've just had my eyes tested and was entitled to a second pair of glasses for free, from a company I won't name.....BigGrin BigGrin .. Spoke to the optician and he made my second pair a lot stronger and these I use now for all the close work, no need for the optivisors. Can't wear them for anything else but then again, I don't walk around the house with optivisors on either.... Solution works for me and I find it more practicable....Cool Cool
Your gun port template should be ok as long as the template is not a tight fit after you've cut the ports out.....
This page was generated in 0.079 seconds.
