2 Pages <12
PLease fix the screw issue!!!! Options
#21 Posted : 18 July 2018 18:37:41
If you are unsure of what screws are to be used for each stage then look at the official build for clarification.
2bob
#22 Posted : 15 August 2018 14:44:23
I'm afraid the official build (issue 70 and 74) is lacking in this case.
Clearly flanged 2.3 x 6mm screws should be used?
#23 Posted : 15 August 2018 15:00:51
My previous answer was about stage 78 and if you look screw sizes are mentioned 13 times in the official build for that stage.
2bob
#24 Posted : 15 August 2018 15:20:46
My mistake.
I'm afraid the official build (issue 70, 74 and 78) is lacking in this case.
Issue 86 of the offical build uses "flanged 2.3 x 6mm self-tapping screw"
when joining the panels.
It seems the magazine and official build pages are a little inconsistent in this case.
#25 Posted : 15 August 2018 15:27:27
The screws to be used in stage 70 are mentioned 9 times and 7 times in stage 74 in the official build for clarification the designers only called for unflanged black self tapping screws to be used in the assembly of the rear body plates.
If you have used flanged screws to assemble these parts you will not have enough of these screws to assemble the front body panel which uses these screws for added support where more items are fitted to that panel.
The rear body panel is fixed directly to the body metal frame so the frame gives that assembly all the support that is necessary.
2bob
#26 Posted : 15 August 2018 15:36:54
I think you're mistaken.
I still have flanged screws left and it appears that more are coming with the final panel in issue 85.
#27 Posted : 15 August 2018 16:35:06
With 16 issues left those screws should be allocated for a future assembly in the build.
2bob
#28 Posted : 15 August 2018 17:42:59
arpurchase wrote:
With 26 stages left those screws should be allocated for a future assembly in the build.
The build guide up to 93 only mentions the flanged screws for the ultrasonic sensor in the front panel and joining the front panels together.
Time will tell, but i suspect there will be a few of these flanged screws left over.
#29 Posted : 15 August 2018 17:49:08
There will be screws left over because many of the issues have spare screws provided in them.
2bob
#30 Posted : 15 August 2018 17:53:41
That's certainly a positive to this build - i'm finding on average 1 spare of each type with every delivery of screws.
2 Pages <12
This page was generated in 0.163 seconds.
