What Glue to use? Options
Chappy
#1 Posted : 17 July 2018 11:58:06
Hi guys
I am from South Africa, I have build a few Artesania model ships, but always just used (cyno Bond) I think its called CA glue?
I want to use wood glue for my next model , but i have no idea what glue to use and how it works,for example putting 2 pieces of wood together does it dry quick or how do you guys do it?
Sorry I am still new to thisMellow
Thanks
#2 Posted : 17 July 2018 12:27:27
Hi Chappy
For most wooden models PVA wood glue is recommended but the best wood glue to get is Aliphatic as it has better penetration into the joints than standard PVA.
A good aliphatic glue should grab in around 30 mins but should be left until fully set before removing any clamps, Pva will take longer to grab than aliphatic but it will not be instant like superglue.
I have added a page from fleabay so you can get an idea what to look for where you live:-
https://www.ebay.co.uk/s...+glue&ul_noapp=true
greg
#3 Posted : 12 November 2018 09:54:01
Rank: Amateur Level 1
One to use Titebond II, nice tip design
clamp for 30 minutes
cleans up easy
one to avoid
gorilla wood glue (brown in color) hard to control flow, takes way to long to set if too much is used
NOW - Building SWIFT 1805
long term goal "USS Constitution"
completed "Fair a Frame" by Model Shipways
This page was generated in 0.090 seconds.
