 Very nice work as always Mark Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Love the replacement seat 👍🏻 “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thank you Andy,Jase for you comments. Regards Markwarren (Mark) Admin
Coming along beautifully Mark, amazing work.... Regards Alan
Many thanks for your comments Alan. I have finished filling all the seam lines and sanded down several times to get a smooth finish over several days. I then masked off the internal area and resprayed with silver aluminium. The inside of the side engine flaps were highlighted and painted, although you won’t see these unless you look inside. The bottom cooling pads were also attached and then highlighted with some wash. Finally, I attached the two side panels/flaps. I just have the top wing vents to fix into place once I have painted them. Then it is onto applying the blue markings on the panels and then a varnish finish. Thank you for looking. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Great to see another fab update, looks superb.... Regards Alan
A lot of work going into this
 Coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you for the kind comments and support, very much appreciated. Mark Regards Markwarren (Mark) Admin
 Hi Mark looks stunning. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Pro     Groups: Registered
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
So looking forward to seeing this come together and all lit up its a stunning piece of work.
The pod has had a coat of gloss varnish before applying the decals. As you can see in the first few pictures, the placement for the decals in the instructions differ from the original prop version. The front part of the pod on the original prop has the blue markings up to where the windscreen goes, whilst the model instructions have the decals beyond the windscreen which is wrong.
I did have a bit of an issue, as it was not as simple as moving the decals down as I originally thought. I had some cutting and rearranging to do to get them in a similar place to where they are on the original prop version. I didn’t place all the decals on at the same time as there were so many to put on, and the pod is a little over 7cm long and I didn’t want to dislodge any whilst handling the model. The whole process has taken me over a week, but I’m quite pleased with the results.
Once I had them all in place, I used some polished aluminium to chip the blue marking, giving them the worn look. I then gave the whole thing another coat of gloss varnish. This is now ready for the final weathering stages once the rest of the parts are in place. You will also see I have painted the seat and head cushion and fixed them in place. Before doing so I bound the main seat with some hessian strips as is shown on the prop version.
Thank you for looking, more soon.
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great progress on this Mark  Looking good with the decals on. Al
Looking special Mark, fab work.... Regards Alan
Amazing work Mark. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Many thanks for looking in guys and your comments. Mark Regards Markwarren (Mark) Admin
Nice work Mark  missed loads of your updates  great to be able to contribute again  is an outstanding build  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Loving the detail and weathering
Really coming to life now mark. well done. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
