How many barrels? Options
gingerale75
#1 Posted : 05 July 2018 11:16:52
Hi Shipmates,
I'm a bit confused how many barrels supposed to be fitted to the deck and where?
In issue 19 the picture shows 2 sets of barrels at the forecastle deck.
However in Issue 117, where they should actually fitted shows one set on quarter deck, front of the compass binnacle.
To make it more confusing the magazine shows one set to be received with issue 19, however I received two sets. Blink
I guess it still can be some personal preference how many and were they fitted, but does somebody know what is the situation on the actual ship?
Thanks in advance.
Happy building!
Laszlo
#2 Posted : 05 July 2018 11:19:09
You can place them to your choosing as they were often moved around the deck
gingerale75
#3 Posted : 05 July 2018 11:20:27
Tomick wrote:
You can place them to your choosing as they were often moved aruond the deck
Thanks Tomick for the quick response.
Happy building!
Laszlo
ronald305
#4 Posted : 15 January 2019 20:55:10
would any one know the color the barrels are suppose to be painted they looked varnished to me in other words they look unpainted with a clear coat
Ronald
gingerale75
#5 Posted : 15 January 2019 20:58:26
Ronald
Hi,
To be honest I’m not sure about the colour of barrels on the real ship but I used dark oak varnish to colour them.
I did not use paint, only the dark varnish.
I hope this helps. Check my diary.
Happy building!
Laszlo
ronald305
#6 Posted : 15 January 2019 21:10:14
ok thanks I will check out your diary
Ronald
Erik A
#7 Posted : 16 January 2019 02:20:01
color doesnt matter... what matters is whats in them.... unfortunately i dont think they had barrels of tequila back then LOL
Current builds
HMS Victory
Endeavour longboat
ronald305
#8 Posted : 22 January 2019 20:30:51
hello there again
would anyone know how to go about painting the bands around the barrels for an alternative to using the 1mm fine line tape because I am unable to find it the tape locally I would order it if I can find it either UK or US BUT NOT China
thank you
Ronald
gingerale75
#9 Posted : 22 January 2019 20:34:59
ronald305 wrote:
hello there again
thank you
Ronald
Hi,
Try Cornwall Model Boats, they are selling pretty much everything what a modeller needs:
https://www.cornwallmodelboats.co.uk/index.html
however you can found on amazon too:
https://www.amazon.co.uk...eywords=1mm+masking+tape
Happy building!
Laszlo
#10 Posted : 22 January 2019 20:40:16
ronald305 wrote:
hello there again
thank you
Ronald
For the small amount you need, simply cut 1mm wide strip lengths from black electrical tape using a modelling knife and steel rule or from masking tape painted black.
ronald305
#11 Posted : 22 January 2019 20:51:37
thanks Tomick
I tried it's very hard to measure 1mm width let alone trying to cut it but I will try again
Ronald
FightingWillie
#12 Posted : 22 January 2019 21:31:02
Rank: Amateur Level 1
I found 1 MM fingernail tape on Amazon. I did have to use black marker on it because there was no straight black. But I did find some black with silver specks in it. It worked great I found 1 MM fingernail tape on Amazon. I did have to use black marker on it because there was no straight black. But I did find some black with silver specks in it. It worked great
FightingWillie attached the following image(s):
ronald305
#13 Posted : 22 January 2019 21:47:04
ok thanks may I ask if the seller was in the US or the UK
FightingWillie
#14 Posted : 22 January 2019 22:52:32
Thobu 1mm Roll Striping Tape Line Nail Art Decoration Sticker DIY Nail Art Tip Decal Decoration Sticker Tool Black. Here is the description I took right off my ordered from Amazon. The seller is out of Asia I live in the US and took about 3 week to get it. I paid just over 2 dollars for a roll.
ronald305
#15 Posted : 24 January 2019 20:36:46
hello again
now that we know the color of the barrels would anyone know the color of the skids from the photo they look like a dark brown but I could be wrong
Ronald
#16 Posted : 24 January 2019 20:56:37
ronald305 wrote:
hello again
Ronald
If you're doing the natural finish then they are natural. Painted finish then they are black as shown in the Official Build diary.
ronald305
#17 Posted : 24 January 2019 21:26:23
Ok thanks Alan
I could not make out the color from the photo
Ronald
This page was generated in 0.173 seconds.
