This is taking shape really well  keep up the good work. Al
Hi mates, Finally the best issue of collection is arrived. I would try the bosyshell to check the ride height and check the fitting om my modified chassis: feels so googd Just a few pic before to stripping out the paint for the future coral paint.        Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
That is looking amazing, keep up the great work. Ken's the name modeling's the game.
It’s amazing how that just pieces it all together. Looking excellent. Mark Regards Markwarren (Mark) Admin
Looking great with the main bodyshell on Al
I'm at finish line with delta (just ramining some final decal to receive) Finally i re start the work on my gti. Watching the staus, i'm not satisfy of the result reached I’ve started a tuned/stanced project but i decided to remade it with extra details to add more realism to my model. Here the status     I need your help to find some references pics to add the missing details The engine kit i think is a PB engine Here i started to work on block. I made hole for engine lift I scribed the head that was absent I now repainted the block in iron mica, the head will be painted in allumium block. If you want and if is it possible i want to share with you my building          Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Before continuing with engine bay (missing some ribs on firewall to be replicated) I make some adjustment work. The oil sump is missing of a parts of block. With styrene I did the new piece (in the next days i’ll paint with color of block) The timing cover is missing of the rear cover.....with styrene i did also this. My attention was to the air intake sistem. I don’t like the oem filter, so i decided to try to replicate the CDA of bmc (that I have really fitted on my Gti mk3) I modified the intake hose. With lego bricks i made the MAF sensor and i used the upper control unit from the 1/8 kit. I finally made the futur carbon box of CDA. With help of PataFix i fitted all the new system to check clearence and space. Next step will be: - fully moulding with putty of hoses and air bix - repainting and use shrink tube for part of hoses - carbon coating of filter box - new bracket to fix the new airbox.                   Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Wow, you've been busy, excellent work. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Wow, you've been busy, excellent work. Mark Thanks Mark, the Delta are quite finished (just waiting some final material to finish the work) So, i restart my project and my all favorite time car. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Guest (5)
