11 Pages «<45678>»
Vw Golf 2 GTI Tuned 1/8 Build Options
#101 Posted : 09 June 2018 11:22:49
This is taking shape really well Cool keep up the good work.
frah2o
#102 Posted : 23 June 2018 07:36:57
Hi mates,
Finally the best issue of collection is arrived.
I would try the bosyshell to check the ride height and check the fitting om my modified chassis: feels so googd
Just a few pic before to stripping out the paint for the future coral paint.
kpnuts
#103 Posted : 23 June 2018 08:03:16
That is looking amazing, keep up the great work.
#104 Posted : 23 June 2018 09:07:37
It’s amazing how that just pieces it all together. Looking excellent.
#105 Posted : 23 June 2018 10:03:08
Looking great with the main bodyshell on Cool
frah2o
#106 Posted : 18 July 2019 08:40:18
I'm at finish line with delta (just ramining some final decal to receive)
Finally i re start the work on my gti.
Watching the staus, i'm not satisfy of the result reached
I’ve started a tuned/stanced project but i decided to remade it with extra details to add more realism to my model.
Here the status
I need your help to find some references pics to add the missing details
The engine kit i think is a PB engine
Here i started to work on block.
I made hole for engine lift
I scribed the head that was absent
I now repainted the block in iron mica, the head will be painted in allumium block.
If you want and if is it possible i want to share with you my building
frah2o
#107 Posted : 18 July 2019 08:41:47
I repainted the head with a silver leaf paint, and whole gearbox and differential in gloss alluminium
I added the missing wire from distributor to ignition coil and i full remade the plug wire in with red cable.
I repainted in green the gearbox cap, in the future i'll put a decal vw logo
I dediced to fill the inside wheel arch with putty to give more deep and realism.
frah2o
#108 Posted : 18 July 2019 08:43:25
I started the work on engne bay. The kit give engine bay separeted from chassis.
I "welded" the engine bay and I started to rebuilt the spar that was all wrong in the model (just notched the chassis)
FInally I try a first check for the inside clearence between chassis and and engine.
frah2o
#109 Posted : 18 July 2019 08:44:28
In past days I continued the work on engine bay. With fiber bond I filled the self made side pods.
I self made a new water tank bracket with alu stripe and I filled the hole on side strut
With the help of Lego bricks I made the missed servobrake and i made a new fitting sistem on engine firewall
I started to selfmade (just finish the final shape) a new clutch lever on gearbox to replicate the future clutch cable (totally missed in the kit)
frah2o
#110 Posted : 18 July 2019 08:45:31
I coated in primer the engine bay to highlight the faults.
I decided to eliminate the wiper tank. I'll fitted an extra engine oil cooling radiator. I remade a modified radiator and i self made a first version of cooling duct.
frah2o
#111 Posted : 18 July 2019 08:46:33
I checked the clearence between bonnet and radiator duct...It's too near. I decided to remade a new shape of duct.
I added joint to radiator for future braided hose
I start to modified the inside high beam projector to create a Venturi duct for cooling the extra radiator. I removed the fluted glass and i fitted a metal mesh. Before to finish this work I nedd to work the headlight for fit the mesh properly.
frah2o
#112 Posted : 18 July 2019 08:47:49
Before to proceed with other engine or gearbox details, i remade whole engine mount system.
The kit has only 1 (the gearbox side and also is not completed) of 3 engine mount.
I remade my best for my skills, the 3 engine mount.
I reinforced the front struts and i used a modified lego brick to match the right angle for front mount
The rear (timing belt side) was totally missing.
I self made an alu bracket.
The two rear engine mount are fixed on subframe to make easier the future fitting of subframe and arms.
frah2o
#113 Posted : 18 July 2019 08:49:05
Before continuing with engine bay (missing some ribs on firewall to be replicated) I make some adjustment work.
The oil sump is missing of a parts of block. With styrene I did the new piece (in the next days i’ll paint with color of block)
The timing cover is missing of the rear cover.....with styrene i did also this.
My attention was to the air intake sistem.
I don’t like the oem filter, so i decided to try to replicate the CDA of bmc (that I have really fitted on my Gti mk3)
I modified the intake hose. With lego bricks i made the MAF sensor and i used the upper control unit from the 1/8 kit.
I finally made the futur carbon box of CDA.
With help of PataFix i fitted all the new system to check clearence and space.
Next step will be:
- fully moulding with putty of hoses and air bix
- repainting and use shrink tube for part of hoses
- carbon coating of filter box
- new bracket to fix the new airbox.
frah2o
#114 Posted : 18 July 2019 08:49:46
i did my best to give more deep to firewall.
With self made paper template i draw the mouldings.
After cheking the size, i’ll made with styrene and then i fixxed
A fast primer coat to check....i think is quite good and look like the real firewall
Finally i check clearence with engine an bodyshell....at the moment is good
#115 Posted : 18 July 2019 20:25:26
Wow, you've been busy, excellent work.Love
frah2o
#116 Posted : 19 July 2019 09:50:20
Thanks Mark, the Delta are quite finished (just waiting some final material to finish the work)
So, i restart my project and my all favorite time car.
frah2o
#117 Posted : 19 July 2019 09:51:08
1/2 post
Yesterday I continued the extra add on engine.
The engine (particularly the gearbox) kit is missing of some detail.
I add the check hole for timing on flywheel...then i painted it in green
I replicate a single gear linkage (as like a Delta hf integrale that i build few months ago)
I finished extra detail on clutch leverage
I started to fix timing cover, alternator (which i added a cable) and water pump. I need fitted these elements to adjust the mistake of the kit for cooling and wiring.
I covered with bare metak foil the spark plugs to imitate the original.
frah2o
#118 Posted : 19 July 2019 09:52:17
2/2
I did my personal best to replicate the clutch cable. With metal wire i did the first visible section.
With a drinking straw, shrink and rubber wire i replicated the clutch cable.
The oil level is orrible from the kit, i remade by myself
I remade the hydraulic joint on the head (i added 2 slot for sensor and future wiring)
Finally i started the work on pulley, i separated them from the printed belt. I’ll made a belt from shrink or elastic.
#119 Posted : 19 July 2019 11:14:42
Some great scratchbuilt detail going into your build Francesco, as always. I love following your work, well done! Drool ThumpUp
frah2o
#120 Posted : 22 July 2019 08:09:19
Thanks Kev Blushing
In the past week i continued the work on engine.
I remade the support/radiator of oil filter.
I also add 2 extra joint for extra custom radiator.
The injectors-fuel rail is very poor from the kit.
I added a lego brick to simulate the fuel pressure regulator and 2 joint for fuel lines.
I also added 4 tube that want remember the 4 injectors.
Finally i painted the rail in metallic red and titanium gold the regulator.
To match the 4 injectors to right size i filled the gap between the duct.
I selfmade the vapors oil caniters with lego brick, i coated it with bare metal foil; i added the hose level and joint to connect to other joint on rocker cover.
I also fitting the nee metal coolant pipes adding the missing hose to waterpump.
I fitted the engine starter and finally I fitted the inlet manifold.
Just some pics in the engine bay to control the fitting and clearence.
11 Pages «<45678>»
This page was generated in 0.277 seconds.
