Joined: 28/08/2017 Posts: 33 Points: 75 Location: East Sussex
Hi all , I am now up to Issue 46 and have planked of the upper gun deck. Has anyone out there used a coloured varnish or other wood stain to provide an authentic look and one I can use on all decks? I feel hat just using a clear matt varnish on the wood provided would not leave the look I want. Any suggestions greatly received. Thanks, Mark
Hi Mark! If its a weathered look your after, have a look at Post 51 on Page 3 of my Messines WW1 diorama where I made up a weathering solution for wood using white vinegar and steel wool. Its basically the same as the ' Weather it' product but far cheaper to make your own. Once the wood is the colour you want then let it dry out and clear matt varnish the decks (or your Victory will smell like a fish and chip shop!) Failing that use a water or spirit based wood stain and dilute it right down so it just 'tints' the wood a coat at a time. Hope that helps. Robin. First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Thanks, Robin. I'll take a look. Regards, Mark
Hi Mark, The colour, shading and weathering of decking is really down to personal preference and the forum has numerous posts on what other modellers have done and their results. Personally, I tend to like the look of Danish Oil, the application of each coat darkens the strips and protects the wood at the same time. For me, two coats of Danish Oil is normally sufficient. Wood stains are good, with a wide variety of shades and colours to choose from. Take a trip to your nearest DIY store, you'll be surprised by the variety on offer. My biggest piece of advice before working on the model itself would be to try doing some test strips using differing stains, washes etc. This will give you a good idea on application and how it is likely to look, from there you can make your decision as to the best way forward for your model. One note of caution, the using of wood stains and washes can be difficult to control, they can very easily spread out to areas you don't want them to go. A look through some of the topics here should prove to be very helpful for you also: https://forum.model-spac...aspx?g=topics&f=102
Regards Alan
