Robi the Robot asks no questions Options
rabosr
#1 Posted : 19 June 2018 22:59:49
Rank: Newbie
Robi wakes up fine and greets all.
He says he will ask questions. At that point his eyes stay lit
but he askes no questions. Complete silence.
It is like he is in a locked up position with the eyes glowing.
HELP- Any suggestions ?
I have waited over 5 minutes for him to ask questions with no luck.
#2 Posted : 20 June 2018 07:19:30
Hi rabosr
Try cleaning the SD card and re-inserting and check for any loose connections to the main circuit board and then try to do the wake up again.
rabosr
#3 Posted : 20 June 2018 14:16:21
Rank: Newbie
Thanks Andy,
Removed the SD cared. Cleaned the contacts
Reinstalled the SD card.
Could find no loose contacks on the board.
Fired up Robi and nothing changed.
Possible defective SD card ?
The last thing Robi says is "waking you up".
#4 Posted : 20 June 2018 14:31:38
Hi rabosr
Can you check the battery for me I presume its fully charged ready for the start up but could you just check how long it takes to charge. What I am looking for is the length of time from charge start where the charger shows a red light until it turns green [ charged ].
Thanks
rabosr
#5 Posted : 20 June 2018 15:06:14
Rank: Newbie
It took 20 minutes to charge the battery.
I don't think it is the battery as I have
tried several time to have Robi wake up
and go through his speech only to lock up
at the same point. (all at one setting).
#6 Posted : 20 June 2018 15:13:43
Hi
Contact C/S for a replacement Stage 70.
