Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,861 Points: 20,900 Location: Northamptonshire, England
Lovely work Jase, nicely detailed Mark Regards Markwarren (Mark) Admin
Thanks Mark, looking forward to getting some paint down Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The rocket has been primed in red, once dry 2 coats of off white were laid down in the arias where the camouflage is needed.
The Hannomag was also primed in the same red primer. I needed three coats of the Ammo yellow which will be the base colour for the truck
I ised smal blobs of panzer putty to mask the dials of the dash board.
JaseFile Attachment(s): jase attached the following image(s): “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Coming on great Jase Mark Regards Markwarren (Mark) Admin
My next focus was the launch stand. this was primed in red as the rest of the kit is. This time O have gone for a late war German green, not seen as often as the dark green used during most of the war this is a much mailer softer olive green. I have used Meng paint for this colour.
everything was then given a black wash to ad some depth and bring out the detail, it also gives a bit of a used feel to the paintwork.
The launch frame comes under intense heat when the V2 launches, never having done burn paint effects before this was a new challenge I started by painting the blast deflector Valleio burnt steel. I then used Tamiya black panel line wash for the wheel flaps. Tamiya weathering powders where then used to add the effect of different temperatures and rust where paint has been striped away by the heat.
I then used a propelling pencil to add paint scratches and worn paint areas such as jack Handels and tread plates.
This completes this part of the kit and has been placed on the display stand prior to final positioning
Jasejase attached the following image(s): “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Brilliant work jase love the burnt paint Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
That blues/black of the launch base is a great touch Jase
Thanks both for the kind words and for looking in, more very soon “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Lovely work Jase, looks excellent, love the detailing. Mark Regards Markwarren (Mark) Admin
Good job on the paintwork Jase. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Making very nice progress Jase, all looking great.... Regards Alan
thanks all for looking in, appreciated “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The Hanomag painting continues with the cabin inter. the roof and the window frame are all natural wood, I used Humbrol leather with a brown wash as a colour match. the bulb in the centre of the roof was painted chrome. the clear plastic part that covers it was painted wood effect before attaching.
Some chipping was done with grey paint and a pencil after giving all the detail a brown wash. the door interims were given a heavy brown wash to look a bit water stained and grubby from use.
the leather seats were painted red brown, given a chocolate brown wash and then a black wash.
the staring wheel and gear shift were both painted matt black, the dashboard was weathered as per the rest of the inter before being fitte. the string wheel attached last, also after some weathering
once happy with this, the glazing was done and then the roof could go on, once again fit is an issue I had to hold it in place while the CA worked its magic.
The doors were then tacky wax fitted closed to allow the camouflage airbrushing to be done. then all the glazing was painted in with Maskol,
Note n Maskol, I have tried several brands over the years still think Humbrols is the best, and its cheaper from the Airfix shop than ebay.
next comes the comouflage painting the doors could then be removed and glued back in place as I wanted them. one piece of glazing was removed to show a window down.
Thats it for now, more soon
The V2 rocket has now been given its base paint. the white was masked off first then the dark yellow went down, was masked off and the dark green was laid down. I used the more regular dark green for the V2 as I am trying to highlight that the various parts of this were manufactured at different times at different places and as the war entered its final months not only were paints officially changed but increasingly any paint to hand was used.
Jase“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Apologies, pictures have been corrected jase attached the following image(s): “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi the painting is looking great,the burnt effect is very well done.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Excellent work Jase, it is taking shape very nicely. Mark Regards Markwarren (Mark) Admin
Colours are really bringing the detail out now. look forward to seeing your progress. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks all for looking in and taking the time to comment greatly appreciated Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The V2 Continues with painting the exhaust and flaps in a mix of burnt steel and titanium. The whole thing was then given a wash using Tamiya grey panel accent. I used a flat brush to not just hi light all the weld spot detail and seams but to add some streak grime.
The whole thing was then given a gloss cote ready for the decals. The aftermarket decal as fantastic and really bring this to life.
With the decals in place the whole rocket was given a matt coat which completes the rocket part of the build
