Joined: 11/06/2018 Posts: 11 Points: 33 Location: Mooresville, NC
I will post some pics later this coming week. I am new to ship modeling although I have done plastic models for quite a long time. This has been really enjoyable for the most part. Anyway, I am almost through Pack 2 and have received Pack 3 with 4 coming at the end of this month. I will be posting pics up to Pack 3 as I probably won't be getting to that pack until I get back from vacation in July. Only minor issues with the kit so far and those are expected from working with wood.
Welcome to ModelSpace, hope you enjoy your time with us and your Constitution build, look forward to seeing your progress
Welcome to Modelspace. Look forward to seeing your build.
On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Welcome to the forum and enjoy your stay with us Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome aboard, great to have you with us..... Look forward to seeing some of your work.... Regards Alan
 Welcome to the forum. I look forward to seeing some of you work soon. We are always here to help. Mark Regards Markwarren (Mark) Admin
Welcome to the forum. Look forward to seeing your progress. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Took some quick pics as I put the stain on the upper deck last night. I went with an antique walnut as the real ship didn't have a very dark deck. I also didn't bother adding the nailheads as I did on the lower deck as they disappear in the stain. The "caulking" in between the boards was added per the instructions, but it somewhat disappears until the stain is added. I did deviate from the instructions a little as I had some warpage on the plywood pieces. If you build as per the instructions you run the risk of gluing a curve in your hull if you have any warping. I also added all of the upper decking planks at the same time as some of the basswood stripes are a little narrow which can lead to issues later on when moving toward the stern. Anyway, I have a busy next week and after that, I am on vacation. I will be jumping back in during early July as pack 4 is on its way to me now. I again am going to deviate a little from the instructions as nothing will be added on the upper deck until the entire hull is completed in pack 7. I also plan to add copper cladding. nichenson attached the following image(s):
That is some very nice work, coming on great.  Mark Regards Markwarren (Mark) Admin
Looks like your off to a great start. Congrats on your "Blue" medal for starting a build diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Looking very nice and the decks look good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum  she's coming along well, nice job so far. Al
Very nice work, great to see your progress.... Regards Alan
Nice work, well done
Thank you everyone for the nice support and comments. I do have some progress pics. I managed to get the starboard side precut "planking." This is such a great idea compared to others I have seen. My only complaint though is that the radius at the front is too great for the narrowed area between the opening for the cannon and the bowsprit. Both sides of mine snapped. It is ok as I basically glued it all back together and used nails to hold the curve that were driven into the plywood for the deck. Anyway, I am hoping that since this didn't take as long as I thought, that I can get the other side at least done before we leave for vacation. BTW, for anyone reading this, micromark sells some really nice sanding blocks designed for ship building. These worked great making the hull ready for planks. I used the wide one over the main portion and the small one at the front and stern portions. nichenson attached the following image(s):
Some very nice work, you are certainly cracking on with this. Mark Regards Markwarren (Mark) Admin
Bit of an update as I have had some free time to get a few things done. Both sides are now on. As you can see though, I had a bit of some trouble. The front pieces snapped in the same spot on both sides. This is due to those pieces being essentially plywood. Other than that, not too many issues. Will start planking the lower hull either tomorrow or Wednesday. Also, anyone want to show me how you nail that last photo in? lol nichenson attached the following image(s):
 Looking good and nice work. As for the bow ply pieces pre-shaping them helps a lot you could have used a couple of methods by either using an electric plank bender to pre curve the ply or the other method would have been to soak the ply in water and then using a suitable curve like a large paint pot or bucket and fixing it in place with elastic bands or tape to hold it overnight. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Making very nice progress, all looking good..... Regards Alan
