Martyn's Cook 250 Endeavour 4 pounder cannon competition build entry Just received my cannon kit . Don't know what I going to do with it yet but got a few ideas Good luck everyone Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Rank: Pro     Groups: Registered
Good luck Martyn  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Good luck
Good luck Martyn, am sure whatever you do will be up to your usual high standards.... will be watching.... Regards Alan
Best of look with your entry Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
All the best in the Cook 250 comp Martyn! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Thanks for the support guys I made a start on this build last night  the gun was cut out and dry fitted to gage the size for the deck it's going to sit on  . The deck was made up out of some 3mm light ply and some spare decking planks  . While it was drying I started gluing the gun together  . I found the wheels stuck out to far from the carriage so adjusted the axles. Next job fitting the barrel and trunnions to the carriage . I have left the trunnions a bit long but will trim them to size later. Today I plan to make the gunwales on the front of the deck Thanks for looking Martyn Martyn Ingram attached the following image(s): Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Great start Martyn. Mark Regards Markwarren (Mark) Admin
Great start
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
Nice start! I will also work later in the evening on the deck and gunwales. Noticed same thing about wheels. I do not know what wood the carriage is made of but it is not easy to work with Regards, Arek
arek wrote:Nice start! I will also work later in the evening on the deck and gunwales. Noticed same thing about wheels. I do not know what wood the carriage is made of but it is not easy to work with Regards, Arek Hi Arek the carriage is made of walnut ply and are very delicate  but quite easy to sand and file I have just started making up the gunwales so hopefully post some pics later Catch you later Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Nice start Martyn  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Nice piece od decking for the display looking forward to your buid Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Nice start there Martyn. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Cheers for the feedback guys Lots of work done on the 4pdr the bulwarks have been fitted to the deck and a few bits and pieces glued to the side  along with the eye bolts for the tackle. The gun was finally attached to the carriage and the trunnion caps fitted. Next job placing the eye bolts in the right position and making the breaching rope . The rope was made with my ropewalk to get the right thickness. It was then fitted to the rear of the gun . A small bit of card was cut out and painted silver to look like lead that cover the touch hole on the real gun Next step making the blocks for the outhaul and Inhaul tackles. The blocks were made off 1x1mm walnut strip. A hole was drilled through and small hooks fitted. The blocks were then fitted to the deck and gun eye bolts and the gun lined up with the gunports . The blocks were then rigged and a small ring was fitted to the breaching rope eye bolts and the rope past through and attached to the eye bolts on the bulwark. Once happy the gun was glued down and a small peace of thread was glued on to hold the lead cover down. Some rope was wrapped around a paint brush covered in watered down PVA to make the ropes for the deck. My next job is to do some whethering and making the tools but that's for next time Thanks for following Martyn Martyn Ingram attached the following image(s): Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Looking good Martyn Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Excellent work, Martyn. Mark Regards Markwarren (Mark) Admin
Looking great so far. Ken's the name modeling's the game.
Excellent, Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
