Issue 94 query Options
Dragon66
#1 Posted : 07 June 2018 09:18:35
Issue 94 says to add deadeyes to top of foremast. Which length do you use for the 6 holes 140mm or 100mm..
Cheers
Confused
#2 Posted : 07 June 2018 09:55:51
Welcome to the forum..... I think you'll find the answer to your query here on the Official Build diary....
https://forum.model-spac...aspx?g=posts&t=3392
Dragon66
#3 Posted : 07 June 2018 10:03:44
Thx for the reply, but even the page just says to insert deadeyes through the 6 holes, it doesnt mention which lengths he uses for it ?. Ive done the 2 sets of lengths as mentioned, and id hate to insert the smaller lengths if they should be the 140mm
Thx
#4 Posted : 07 June 2018 10:34:09
Thx
Official build says to make up 24 x 140mm lengths and 8 x 100mm lengths. Also says the mizzen mast only has 8 deadeyes. 12 x 140mm are used for each of the main and foremasts, that uses up your 24 x 140mm lengths. 8 x 100mm are for the mizzen mast, 4 on each side....
Hope this helps..
Dragon66
#5 Posted : 07 June 2018 10:39:47
Aaahhh that makes sense, thanks for your help, Nelson will be pleased lol
