8 Pages «<45678>
RAF 100 Build Entry - Airfix 1/72 AVRO Vulcan B Mk2 XH558 Options
#101 Posted : 07 June 2018 00:25:40
Good to see this taking shape BigGrin nicely done Gray.
#102 Posted : 07 June 2018 12:58:49
Cool progressing Nicely.BigGrin Drool
#103 Posted : 18 June 2018 19:11:32
BigGrin Hi guys, thanks for looking in, and your comments Cool
Today's update: both halves of the fuselage are cemented together, and wings, tailfin and undercarriage doors attached. Next is the laborious process of gap filling Bored. Everyone said because of the age of the kit it's a bit of a 'filler queen' (queue music BigGrin'.However, Vallejo's Plastic Putty is doing what it says on the tin, so onwards and upwards
#104 Posted : 18 June 2018 19:51:36
Sure you`ll sort the gaps out ok, its just gonna take some time.
Good luck.BigGrin
#105 Posted : 18 June 2018 20:03:48
Good to see the wings and fin attached BigGrin hopefully one day Airfix will revisit the kit and put some of the fit issues right.
#106 Posted : 18 June 2018 20:17:18
I hope so Al, because it’s a beautiful plane. Apparently the Victor is a much better kit (got that one too Love )
#107 Posted : 18 June 2018 21:05:00
Good luck.BigGrin
True Del, it’s the end result that counts ThumpUp
#108 Posted : 19 June 2018 07:25:07
BigGrin Coming together nicely and looking goodCool
#109 Posted : 19 June 2018 09:58:12
Looking good, there is plenty of rubbing down you have. I also use the Vallejo Plastic Putty, great stuff and sands down very smoothly.Cool
#110 Posted : 19 June 2018 15:39:54
Making lovely progress Gray, despite the amount of seam filling you have to do.... Cool Cool .. Am sure all your efforts will be worth while when you see the end result....Cool Cool
#111 Posted : 03 July 2018 14:02:49
looking very good grey look forward to seeing your progress. Cool BigGrin
#112 Posted : 03 July 2018 19:12:55
Thanks for looking in guys Cool Just awaiting paint then sprint to the finish ThumpUp
Cheers Gray
#113 Posted : 24 July 2018 19:55:30
Time for another update. I have to confess i have never used an airbrush before Blushing , so i thought it was about time i gave it a go.
Having purchased what i researched to be a reasonable but cheap compressor kit to go with my Badger airbrush (details can be found here:
http://forum.model-space...spx?g=posts&t=20580 ), i decided to give it a go BigGrin
Two coats of Vellejo Model Colour primer and this is where we are at!
Not perfect, i admit, but i'm quite chuffed that i actually did it! I can see how it is easy to get hooked on using an airbrush.
So, can you tell what it is yet Blink Flapper Laugh
#114 Posted : 24 July 2018 20:25:57
Coming along nicely GrayBigGrin that's a lot of plastic to cover.
#115 Posted : 24 July 2018 20:58:31
Making great progress. an Airfix kit is great for howning filling and sanding skills LOL
looking good
#116 Posted : 24 July 2018 23:14:04
You'll be amazed what you can do with an airbrush. Looking great Gray, look forward to seeing more....Cool Cool Cool
#117 Posted : 25 July 2018 07:18:17
BigGrin Looking good and you have done a nice job on herCool
#118 Posted : 25 July 2018 20:35:31
You're not kidding Al BigGrin She certainly takes some covering!!!
Thanks for looking in and your comments, guys, always welcome ThumpUp
Here is tonight's update. Just finished second coat of white for the underside of the fuselage & Blue Steel. Leaving it to dry overnight, sand down where needed, and then another coat me thinks.
#119 Posted : 25 July 2018 21:49:02
Looking really good Gray, Love hope you’ve got plenty of paint.
#120 Posted : 26 July 2018 06:34:56
Looking forward to seeing this cross the line
i see Airfix are about to re-release it again
8 Pages «<45678>
This page was generated in 0.316 seconds.
