26 Pages <12345>»
MWG build diary of the Bark HMS Endeavour Options
#41 Posted : 23 June 2011 22:12:56
Next up is to do some shapeing of the balsa fillets I fitted to the base of the Hull.
I prefer to shape alittle bit at a time, its along build ( 100 issues ) so I do not have to rush, I can stand back and review each time I do it.
You will see any progress when you look back on the build, here we are:-
#42 Posted : 23 June 2011 22:20:00
There is not alot to see there but it will make my life easier when I come to plank.
The final photos cover the fitting of balsa fillet,which I have done to the Top sides of the Hull ( They have to be sanded next ) here goes:-
#43 Posted : 23 June 2011 22:27:50
All held together with one of my favourite Long bars.
Issue 24 due out in two weeks time ( 7th June )will supply us with 2 swivel guns and nothing else!!!!! Still I will be sanding the Hull getting that right. thank you for lookingBigGrin LOL
#44 Posted : 26 June 2011 17:23:55
Hi again, did some fairing of the Hull particulary around the balsa fillets at the stern, and work on the port side bottem of the hull, again balsa fillets, slow process but I have loads of time, so no rush, here are the photosBigGrin
jonny7england
#45 Posted : 26 June 2011 17:30:23
The planking should go on a treat when it's faired mate, did the same with the stern and bow of my Victory, once glued, the planks were pretty firm...Keep the pics coming...ThumpUp
#46 Posted : 26 June 2011 17:37:11
Cheers Jonny
#47 Posted : 02 July 2011 23:25:13
Hi again, the next job to do is line the rear deck Bulwarks.
You use stips of planking that have been left over from when you planked the Decks, see photo
#48 Posted : 02 July 2011 23:31:44
Now run some glue along the length of the plank (I use Aliphatic for better adhesion) place it on the Bulwark, and clamp it in place.
Repeat the procedure for the other side, and leave to harden, it will look like this:-
#49 Posted : 02 July 2011 23:37:14
The remainder of the rear Bulwark, we will line when the first part we have done is set. the next photo shows the part we have still to do.
#50 Posted : 02 July 2011 23:40:39
This is how the Ship looks at the moment and that is all for nowBigGrin HAPPY MODELLINGLOL
Foz
#51 Posted : 03 July 2011 11:20:10
MWG that looks a great build there, and cant wait to get back to mine but want to sort the old Vic out first.
I love the colour of your decks, what colour did you stain them?
Keep those pics comming and have fun
Foz
#52 Posted : 03 July 2011 12:46:46
Hi Fozy,
I built the decks in one piece before fitting to the Ship,I then sanded them, stained them ,then sanded them again to obtain a slightly lighter colour, then fitted them to the ship ( I did not fit first because this stain will "BLEED")LOL
Then used a water based varnishBigGrin
#53 Posted : 03 July 2011 16:12:44
Next up we remove the clamps from the work we started on the rear deck bulwark, the lineing is higher at this point, we will need to sand it down laterBigGrin
#54 Posted : 03 July 2011 16:17:42
We will now finish lineing the last 1/3rd of the rear bulwark, apply the glue to the plank fit it and clamp it.And repeat for the other sideMellow
As you can see the plank does not fit to the top of the Bulwark, we will add a couple of fillets next, when what we have done so far BigGrin is set.
#55 Posted : 03 July 2011 16:23:56
This is how she looks at this stageLOL
We will trim the planks at the end when they are set.
#56 Posted : 03 July 2011 16:59:57
Next job is to trim the planks at the bulwark stern. done. now we need to add fillets of planks to make up the height of the rear of the bulwark.
First take a further piece of plank and cut it in approx two halves.
#57 Posted : 03 July 2011 17:05:31
We apply the glue to these two halves, clamp them and leave them to set.
Our next job when the planks are set is to sand the planks level with the top of the stern Bulwark.BigGrin
#58 Posted : 03 July 2011 17:18:00
This work is shown in official issue 22:-
#59 Posted : 10 July 2011 22:03:53
Hi again, last time we lined the rear Bulwarks, they ended up like this:-
#60 Posted : 10 July 2011 22:08:22
We need to trim these edges flush with the rear Bulwarks, useing a model Knife and a nail emery board, this is the result:-
26 Pages <12345>»
This page was generated in 0.806 seconds.
