Cook 250 - Endeavour cannon biuld competition entryThis will be my "Cook 250" diary. Not quite sure what to do fully yet, but have an idea mulling around in my head. That`s the first job  getting it out of my head onto paper. Should find the trigger by 1st June for the big reveal. See you all then and "Good Luck" to all other entrants. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Pro     Groups: Registered
Joined: 22/03/2016 Posts: 175 Points: 552 Location: Merseyside
Good luck to you Del Built- Shelby Mustang, Lamborghini Huracan Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
 Good luck in the comp Derek Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good luck with your entry
Good luck with the comp Derek, look forward to seeing how it all turns out.... Regards Alan
All the best in the Cook 250 comp Del! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good lick Derek  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks for the support. So with only days to go a plan is formulated. This cannon is not large, therefore to make sure I can find it again it needs to be bigger. As I`ve got to build the cannon supplied it needs to be on something to make it noticeable, ie a bit of deck section. Attached below is what I`m going to try and get close to. No main rigging and I`ll see how time goes for the bucket.(See pic below) Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looks like a good plan Ken's the name modeling's the game.
Well this is where it all starts. Had a dig in the modelling room at the weekend and found just about everything I need for the addition to the cannon itself. To give you an idea of the size of these scraps the ply base is 12 inches by 8 inches, so way more than I need. (See Pic) Next job is to build the cannon and verify the scale of the deck section. That`s the theory anyway. More soon. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice start Derek Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Great start Derek Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
Plenty of material! Best of luck with your build! Regards, Arek
Nice start Derek, looking forward to seeing what you can do with your scraps. Mark Regards Markwarren (Mark) Admin
Never throw anything away just incase Looking forward to what you conjure up Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great to see you starting this Derek, will be watching to see what you come up with.... Regards Alan
Thanks for the encouragement and support. Having looked at several reference pics and used some degree of "guesstimate" (is that a word  ) as to the scale, this is where I`m at. Plywood base marked out with the lines indicating where beams should be underneath for tree nailing down the deck planks. Next is the basics of the cannon. Started painting the carriage using a flat red and the cannon itself painted with Tamiya gun metal. Now for the deck. I wanted a little bit of depth to this part of the build rather than a flat piece of deck. So 5x5mm deckbeams holding up the deck which is where the tree nails will be lined up when the deck planking is laid. That`s my knowledge of ship parts exhausted  , so built the lower section of the ship rails and a bit of outer planking. Final pic puts the partially built cannon on the deck position. Coming up soon is the ships upper rail and supports, a bit more on the cannon and time permitting a bit of deck planking. Absolutely no idea how long that lot may take, so will update when something substantial worth adding. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great start Derek! Love the idea of deckbeams! Something that didn't even cross my mind... Regards, Arek
Nice work Derek, coming along nicely.
