 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 16/02/2015 Posts: 76 Points: 80 Location: USA Phoenix
Because of the black color of the stern gallery port openings and also the port covers for the lower port openings I am not sure of there configuration of the placement of those port covers due to the lack of contrast seen in the instruction photo for stage 72G. I assume that the port cover completely cover the port openings.
You are correct the port covers do cover them completely. They are a tight fit so test fit them then place the upper port 1st then butt the lower port to the upper port. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
