12 Pages «<7891011>»
Pete's R2 build Options
Ritchie69
#161 Posted : 29 May 2018 13:59:42
Cheers for that Mark. All sorted.
Peter
Completed - R2D2
TRGRichie
#162 Posted : 29 May 2018 18:49:25
Great to see this coming together so well
Rich
AUTO FRUMP STOMPER
#163 Posted : 29 May 2018 20:16:32
Coming along well, nice work.
Ritchie69
#164 Posted : 24 June 2018 10:35:39
The next 4 issues have arrived and built. We are now 3/4 of the way through.
Issue 73
The parts list, 2 x internal supports, 4 spacer rods and various fixing screws.
We take the frame form stage 71 and attach the 4 rods and 2 supports.
Ritchie69 attached the following image(s):
Completed - R2D2
Ritchie69
#165 Posted : 24 June 2018 10:35:45
Issue 74
The parts in this issue, left side body panel, shoulder seal, external side grill, external rear grill and 3 panel conectors.
We attach the shoulder grill to the panel (no scews used), then slide the side grill onto the blue back panel then attach to the left side back panel and secure with 2 selft tapping screws. Repeat for the rear grill.
Take the panel connectors and left side body panel and secure the connectors to the panel with self tapping screws. Now take the panel from stage 70 and attack them together. This now completes the back of the body.
Completed - R2D2
Ritchie69
#166 Posted : 24 June 2018 11:11:09
Issue 75
The parts for this issue are 3 middle ring parts and 3 connectors.
Take all parts and 6 silver screws. Attach 1 connector to 1 part of the middle ring. Repeat for all the parts until the ring is complete.
Take the assembly form stage 73 and more silver screws (two 8mm x 2.5 and four 4mm x 2.5). Place the middle ring assembly on top and align the holes with the rods and supports, secure with the screws.
Completed - R2D2
Ritchie69
#167 Posted : 24 June 2018 11:21:34
Issue 76
The parts in this issue are, left front body panel, shoulder seal, heat exhaust grill & shell, external front grill & plate, allen screws and various screws.
Attach the shoulder seal to the body panel. Assemble the exhaust grill & shell and secure with a self tapping screw. Attach to the panel using 2 self tapping screws. Take the external grill and slide it over the plate, attach to the panel with 2 self tapping screws.
Take the dome and the plastic allen screws. Remove the screws from sprue and fit to the internal frame to secure the panels.
Completed - R2D2
#168 Posted : 24 June 2018 20:20:09
Well done Pete, a nice detailed diary and your build is coming on great 👍
Regards Gray
#169 Posted : 24 June 2018 21:42:24
BigGrin looking good and nice workCool
Ritchie69
#170 Posted : 28 June 2018 07:26:26
Thanks all BigGrin
Peter
Completed - R2D2
#171 Posted : 28 June 2018 11:25:03
Nice update, coming on nicely.BigGrin
#172 Posted : 28 June 2018 14:48:39
Nice work Peter, looking good.
Coser
#173 Posted : 28 June 2018 16:37:11
He's really coming along now, must admit that once the saber tube is installed and the wiring is tidy, it really looks a professional job.
However, I do have a quick question. I get mine on a weekly basis from my local newsagents, so it is possible that I have missed something along the way. Have we had anything to put behind the big, blue, squareish thing with the large black lens? I have a black plastic mount there, but nothing mounted to it, so I don't know if I have missed an issue somehow, or if it's for a future issue.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
Ritchie69
#174 Posted : 28 June 2018 19:04:04
You haven't missed anything as of yet. Mine is the same, nothing issued for that space.
Completed - R2D2
Ritchie69
#175 Posted : 27 July 2018 18:58:17
I've finally got round to updating this months build. Quite a bit to do as we near the end of the build, as everything is now starting to come together.
Issue 77
Parts in this issue are Dome screws, leg support, Cable organiser & ties.
Screw the L bracket to the leg support. Then screw the leg support to the body frame.
Screw the last 3 screws to the inside of the dome. Take the lightsabre assembly from issue 37 and the cable organiser. Wrap the cable organiser around all the wires, then cable tie to the side of the lightsabre assembly.
Screw the lightsabre assembly into the dome in the space provided.
Then carefully attach the wires for all the dome electronics to the circuit board inside the dome.
Completed - R2D2
Ritchie69
#176 Posted : 27 July 2018 19:15:56
Issue 78
In this issue we get the following pieces, Tool housing, tool arms & connectors.
Separate the 3 fingers from the sprue and using some super glue attach them to the head of the tool arm. The glue the head onto the rod. Repeat for both of the tool arms.
Attach the tool arms to the tool housing. Then attach the door panel to the housing.
Take the front panel and slide the door into the gap and screw the housing to the panel. Attach the connectors.
Completed - R2D2
#177 Posted : 27 July 2018 19:15:59
Looking good and as you say its all starting to come together nicely.
Cool Cool Cool Cool Cool
WTG
#178 Posted : 27 July 2018 19:18:43
BigGrin Looking d=good and starting to fill those spaces nowCool
Ritchie69
#179 Posted : 27 July 2018 19:29:31
Issue 79
In this issue we get a leg support, spacer rod & fixing screws.
Screw the L bracket to the leg support, then screw the leg support to the body frame. Screw the spacer rod to the frame.
Completed - R2D2
Ritchie69
#180 Posted : 27 July 2018 19:38:06
Issue 80
Parts in this issue, front panel, some body details and the control switches.
Attach the body details to the front panel and screw them into place.
Take the control switch buttons and place in the body panel and screw it into place. Then screw the control switches onto the back casing and screw the metal bracket to it. Place the switches over the buttons and screw the metal bracket to the body panel.
Completed - R2D2
This page was generated in 0.381 seconds.
