Configuration of port covers in stage 72G Options
m0325
#1 Posted : 28 May 2018 20:30:12
Because of the black color of the stern gallery port openings and also the port covers for the lower port openings I am not sure of there configuration of the placement of those port covers due to the lack of contrast seen in the instruction photo for stage 72G. I assume that the port cover completely cover the port openings.
#2 Posted : 28 May 2018 20:38:24
You are correct the port covers do cover them completely. They are a tight fit so test fit them then place the upper port 1st then butt the lower port to the upper port.
m0325
#3 Posted : 29 May 2018 15:38:50
Thank You
This page was generated in 0.089 seconds.
