Joined: 08/08/2017 Posts: 52 Points: 210 Location: basildon/thurrock
The start of the body framework. close up of the screws protruding which they are supposed to do supposedly bigliz7 attached the following image(s):
final pics now of the first panel of many for the body didn't take long and also a link to the video https://youtu.be/Jk1gE9RBv9Ibigliz7 attached the following image(s):
Markwarren wrote:Looking good, coming on very nicely. Mark Thanks mark
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Coming on nicely. Peter Completed - R2D2
 Lots more panels to go and more goodys to add and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
New issues 69-72. The frame consisting of issues 69 and 71 bigliz7 attached the following image(s):
issue 70 putting details on and connecting the two panels together bigliz7 attached the following image(s):
issue 71 connecting the ring together and putting on the frame from issue 67. Side note make sure the part bf 20 with the writing upside down on one side so they mirror each other like in on of the pics bigliz7 attached the following image(s):
Final issue of this month fitting the speaker. #make sure the arrow is at the bottom and the notch also bigliz7 attached the following image(s):
Last pic was supposed to be this lol bigliz7 attached the following image(s):
Nice update, coming along very nicely. Mark Regards Markwarren (Mark) Admin
Joined: 02/01/2017 Posts: 92 Points: 290 Location: Kintbury, West Berkshire
bigliz7 wrote:issue 71 connecting the ring together and putting on the frame from issue 67. Side note make sure the part bf 20 with the writing upside down on one side so they mirror each other like in on of the pics I had this moment - thought I'd built it wrong so went back over the steps and didn't find any mention of it so unscrewed the part and flipped it around,
LSainsbury wrote:bigliz7 wrote:issue 71 connecting the ring together and putting on the frame from issue 67. Side note make sure the part bf 20 with the writing upside down on one side so they mirror each other like in on of the pics I had this moment - thought I'd built it wrong so went back over the steps and didn't find any mention of it so unscrewed the part and flipped it around, It does say in the magazine dont know off by heart but i read it in the magazine to turn it upside down
Hi, Step 5 in Issue 71 is where it tell you to "Turn the new BF-20 over so the part number is on the underside".
Hope this clarifies the issue.
