Hi jonny! It doesn't matter when you start a build dairy, I'm just glad you have. I found it a great help, it makes you think what you're doing and the brake from building can save you from rushing ahead. It's good to stop and reflect on your work, keep the rest of us upto date on your build. Good luck mate!
got me one of those a few months back, well worth having.
How are you getting on with the planking Jonny?
Hi Colin...yeah. it is a terrific little tool...and as for the planking, I can happily say... WHOOPEE!!! Completed it, now I am on the lower wales section...I hope to get some pictures up here soon... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
good news mate, Im starting again as of yesterday (back to work tomorrow) but I wish I kept to the planks supplied arghhh!!!! these 2mm planks are taking forever, I guess it will look good in the end but I see NO END..
Jonny your builds looking great, looking forward to the photos of the planking. ( Thank goodness I`ve finished mine ) MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi jonny7england! It is a good little plane and a lot safer than a razor plane, you will be glad that the lower planking is done mate! I know that WHOOPEE!!! feeling.
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi Johnny,
Looking good mate, keep it up.
Can I ask where you purchased the mini plane?
Thanks
Wilfy
Wilfy the Sea Dog wrote:Hi Johnny,
Thanks
Wilfy Try this... http://www.toolsdiy.co.u...ions.price,ASC&qS=46Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Johnny
Which technique did you use to pull that troublesome rib 15 back online?
This is the thing that's still holding me back on my build.
Your build is looking very good.
Kind regards
ajbird74 wrote:Hi Johnny
Kind regards
Tony Thanks for the comments...I have built up rib 15 where needed on the outside and on the inside where the top of rib 15 took an inward direction...I gently sanded it back, but always checking with each layer of planking that I applied...so far, it has not been too much of a problem..Hope I have helped??? Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Guest (7)
