I Need some help please with the Transom Options
frank1964
#1 Posted : 26 May 2018 20:09:00
Rank: Newbie
I did not follow the instructions, of course, but on the Transom there are 4 notches that I should have cut away the planking strips. I covered them with the walnut strips and I am unable to locate them now.
Could someone please send me the measurements of the locations, If possible I will measure from the top of the stern gun port edge up to the notches.
Thank you in advance for any help,
Frank
frank1964 attached the following image(s):
#2 Posted : 26 May 2018 21:31:01
If you measure down from the top of the radius down, the measurements are to the top of each notch.
Hope this helps you, and good luck with the rest of your build.
frank1964
#3 Posted : 26 May 2018 22:06:34
Rank: Newbie
Yes, that helped a great deal chris. Thank you for taking the time to answer.
Frank
This page was generated in 0.162 seconds.
