Looking very nice, won’t be long before the little fellow will start chirping. Mark Regards Markwarren (Mark) Admin
Nice work, you will soon be onto the body.
Joined: 02/01/2017 Posts: 92 Points: 290 Location: Kintbury, West Berkshire
It's that time of the month! Issues 66, 67, 68 and 69 now completed. Only problem I had this month was screwing in one of those tiny plastic allen pins - it it's anbout half way in and I can't bet it to budge any further. Don't think it'll be an issue. I also have another issue with I'll be posting about shortly. LSainsbury attached the following image(s):
Hi LSainsbury You will have three spare allen heads once they are all fitted into the Dome so one of those can replace the problem one. It also looks like your missing a countersunk hole in the frame parts contact C/S for a replacement. Looking good. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice update Lee, coming on very nicely. Mark Regards Markwarren (Mark) Admin
arpurchase wrote:Hi LSainsbury
Looking good.
Andy Cool - thanks for the info and yes the countersunk hole question was posted in another post and now sorted in the next update.
Happy May 2018! Another update from my R2D2 Build... Issues 70,71,72 and 73 have arrived - along with a replacement issue 67 as I was missing a countersunk hole in one of the plates. LSainsbury attached the following image(s):
 Rank: Beginner Level 1 Groups: Registered
LSainsbury wrote:It's that time of the month! Issues 66, 67, 68 and 69 now completed.
I had some issues screwing in the plastic allen pins, if you pop them in the freezer for 10 mins or so they shrink slightly and are easier to screw in. I’m having issues with the spacer rods that don’t have any thread to screw into, so that’s been reported to C/S. Also the miss coloured back panel BP-07 that doesn’t line up correctly without leaving a gap at the bottom and a step at the top. I just can’t get it to line up no matter how I try, so I’ve also requested a replacement part.
Issues 74,75,76 and 77: Received my replacement issue 68 panel but it still looks a bit off. The white on the inside is more white than outside. It's a better fit though but still has a bit of step at the top. LSainsbury attached the following image(s):
Nice work Lee. Looking excellent. Mark Regards Markwarren (Mark) Admin
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Looking good Lee, 3/4 the way through Peter Completed - R2D2
 Coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely progress, heading towards the final straights now.... Regards Alan
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
Looking Good, very exciting times now
Issues 78, 79, 80 and 81. Once again I nearly had a screw mishap with issues 78 while putting the tool arms together!! All good now though. LSainsbury attached the following image(s):
 Looking good and starting to come together now Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Looking good and starting to come together now Yes - my screw issue was that I used some long black - think they were 11mm screws to attach the small hinges to the tool door. The actual tools are using the correct long half threaded screws - I'm sure there should have been two more for those hinges. Can you confirm what the correct screws should be?
If you check the official build diary for issue 78 it confirms what screws are to be used for this part of the assembly. Always check the official build if you are unsure of something. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Lee Mark Regards Markwarren (Mark) Admin
Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Another little R2 coming along nicely 😁 Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
