Body panels different sizes Options
James H
#1 Posted : 23 May 2018 19:47:26
Hi all,
Just received my new pack of parts and when I fit the body panels together, the two are different heights. About 1.5mm difference. With the panels flush at the bottom, this is how they look at the top.
Anyone else got this problem? What is the correct panel height supposed to be as I don't know which is wrong.
#2 Posted : 23 May 2018 20:03:26
Hi James
Can you see if the brackets that join the two parts are seated correctly if they are then reorder the faulty part for a replacement.
James H
#3 Posted : 23 May 2018 20:08:15
arpurchase wrote:
Hi James
All the brackets seat properly, but I don't know whether it's the first panel or the new delivery which is the faulty panel. If I knew the height of the panel in mm, then I can measure them and determine.
Thanks for replying.
mpfiend
#4 Posted : 23 May 2018 22:02:18
Hi James
Mine are the same too, the right hand panel in your photos seems shorter top and bottom compared to the left one. When I saw this in my build I looked at the official build log for issue 70 and in certain photos it looks to be the same, it can also be seen in the build log for issue 72 if you look carefully. So perhaps all parts are like this?
Keith
James H
#5 Posted : 23 May 2018 22:14:52
mpfiend wrote:
Hi James
Keith
Thanks for the intel. Good to know, and it'll be interesting to see how this pans out.
coldsweat
#6 Posted : 24 May 2018 07:04:54
Rank: Amateur level 2
Mine are like this too - I have a feeling they'll all be like it, coming from the same mould & all!
Spudtrooper37
#7 Posted : 24 May 2018 07:56:11
Mine are like this but I made sure the top was flush because this is more visable
Darren
#8 Posted : 24 May 2018 14:10:31
R2 has gone together pretty well so far as you can see from the photos shown below (taken at Issue 91 with the panels and dome loosely placed over the completed frame), the end result looks good Cool
The slight 'step' will be minimised and not pose a problem if it’s distributed top and bottom, rather than all at one end.
James H
#9 Posted : 24 May 2018 14:14:06
Cheers. Looks great when done. Odd how the difference in size passed inspection. Laugh
#10 Posted : 24 May 2018 14:20:55
Probably passed because it does not pose a problem
#11 Posted : 24 May 2018 14:21:08
semaj
#12 Posted : 24 May 2018 22:33:21
mine are ike this too, i just positioned them as a 'best poss' placement, so it was roughly even top and bottom. i dont think it will pose much of an issue tbh
Building:
Complete:
LSainsbury
#13 Posted : 26 May 2018 13:15:34
James H:
Mine are like this as well - slight off-colour between panels as well.
I'll be re-ordering the panel.
LSainsbury attached the following image(s):
LSainsbury
#14 Posted : 26 May 2018 13:28:34
I've now requested a replacement issue 68.
jennings74
#15 Posted : 28 May 2018 12:47:48
I’ve had the same problem, I’ve just contacted C/S about a replacement part
