Good luck with the comp Chris and of course hope your build goes to plan... look forward to seeing how you progress..... Regards Alan
Good luck Chris Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Good luck “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Good luck in the Cook 250 comp Chris! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Guys, Made a start today. Firstly I cleaned up all the parts. Then took to re-shaping the cannon barrel. I then built up the carriage and gave it a coat or red ochre. I installed the wheels and drilled out the shafts for the pins. Mean while I had the barrel in Blackener. Once done I glued Tin foil to the rear.
I will post more this week.
Cheers Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking great Chris
 Great start Chris Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Nice start Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
Nice start Chris!  Tin foil??  interesting... Regards, Arek
Nice start, good luck with the entry
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,867 Points: 20,918 Location: Northamptonshire, England
Nice start Chris. Mark Regards Markwarren (Mark) Admin
Looking the part Chris. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks for the nice comments guys. I haven't decided where I'm going with this one but am copying a picture of one so may just recreate that picture. Hopefully!
Here are the latest pics. I've moved the metal stays to where they should be, also added the wheel pins now the brass is black. I added the cannon barrel tied down rigging.
Looking sweet Chris, lovely work....  .. Good luck with your entry.... Regards Alan
Liking that a lot. Ken's the name modeling's the game.
Looks great I like the rain cover “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great attention to details! Regards, Arek
Thanks for the comments guys, much appreciated.
I have started on the base, which is set to a specific size. I will reveal later why but its not what you would expect.
Here are the latest pics, as mentioned i did the base also i have installed the caps and pins on the cannon barrel.
 Mmm intriguing about the size of the base  Really looking forward to the next update  . Lovely job Chris Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
