3 Pages 123>
Delboy`s Cook 250 build Options
#1 Posted : 19 May 2018 06:38:58
Cook 250 - Endeavour cannon biuld competition entry
This will be my "Cook 250" diary. Blink Blink
Not quite sure what to do fully yet, but have an idea mulling around in my head. That`s the first job Crying getting it out of my head onto paper.
Should find the trigger by 1st June for the big reveal.
See you all then and "Good Luck" to all other entrants.Cool
TRGRichie
#2 Posted : 19 May 2018 07:14:22
Good luck
Rich
AUTO FRUMP STOMPER
usersteve83
#3 Posted : 19 May 2018 07:20:24
Good luck to you DelCool
Built- Shelby Mustang, Lamborghini Huracan
Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
#4 Posted : 19 May 2018 08:08:26
BigGrin Good luck in the comp DerekCool
#5 Posted : 20 May 2018 01:40:14
Good luck with your entry Cool
#6 Posted : 20 May 2018 10:08:35
Good luck with the comp Derek, look forward to seeing how it all turns out....Cool Cool
#7 Posted : 21 May 2018 11:48:42
All the best in the Cook 250 comp Del!Cool
#8 Posted : 21 May 2018 16:34:09
Good lick DerekBigGrin regards PhilCool
#9 Posted : 26 May 2018 06:40:53
Thanks for the support. Cool Cool
So with only days to go a plan is formulated.
This cannon is not large, therefore to make sure I can find it again it needs to be bigger.Blink Blink
As I`ve got to build the cannon supplied it needs to be on something to make it noticeable, ie a bit of deck section.
Attached below is what I`m going to try and get close to. No main rigging and I`ll see how time goes for the bucket.(See pic below)
kpnuts
#10 Posted : 26 May 2018 08:04:05
Looks like a good plan
#11 Posted : 04 June 2018 17:20:50
Well this is where it all starts. Blink Blink
Had a dig in the modelling room at the weekend and found just about everything I need for the addition to the cannon itself.
To give you an idea of the size of these scraps the ply base is 12 inches by 8 inches, so way more than I need. (See Pic)
Next job is to build the cannon and verify the scale of the deck section.
That`s the theory anyway.LOL
More soon.
#12 Posted : 04 June 2018 18:17:34
BigGrin Nice start DerekCool
#13 Posted : 04 June 2018 18:19:47
BigGrin Great start Derek Cool
Martyn
arek
#14 Posted : 04 June 2018 21:41:08
Plenty of material!
Best of luck with your build!ThumpUp
Arek
#15 Posted : 04 June 2018 22:05:54
Nice start Derek, looking forward to seeing what you can do with your scraps.BigGrin
#16 Posted : 04 June 2018 22:53:01
Never throw anything away just incase
Looking forward to what you conjure up
#17 Posted : 05 June 2018 08:40:18
Great to see you starting this Derek, will be watching to see what you come up with....Cool Cool
#18 Posted : 05 June 2018 18:13:09
Thanks for the encouragement and support.Love Love
Having looked at several reference pics and used some degree of "guesstimate" (is that a word LOL ) as to the scale, this is where I`m at.
Plywood base marked out with the lines indicating where beams should be underneath for tree nailing down the deck planks.
Next is the basics of the cannon. Started painting the carriage using a flat red and the cannon itself painted with Tamiya gun metal.
Now for the deck. I wanted a little bit of depth to this part of the build rather than a flat piece of deck. So 5x5mm deckbeams holding up the deck which is where the tree nails will be lined up when the deck planking is laid.
That`s my knowledge of ship parts exhausted Blushing, so built the lower section of the ship rails and a bit of outer planking.
Final pic puts the partially built cannon on the deck position.
Coming up soon is the ships upper rail and supports, a bit more on the cannon and time permitting a bit of deck planking.
Absolutely no idea how long that lot may take, so will update when something substantial worth adding.
arek
#19 Posted : 05 June 2018 20:07:19
Great start Derek! ThumpUp
Love the idea of deckbeams! Something that didn't even cross my mind...
Arek
#20 Posted : 05 June 2018 21:13:53
Nice work Derek, coming along nicely.
3 Pages 123>
