 Rank: Pro     Groups: Registered
Loving your work as always Rich
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
Thanks Rich. I've finally got a roadster tail cast and cut open the boot lid. It's quite rough at the moment and will need a good deal of sanding and filling. I've done a bit of weathering on the fuel tank as the real car is still quite rough in many areas as the restorers didn't want to go too far with the work and only 'renovated' it as they put it, so the car is still very much quite scruffy in many areas. Lots to do on the tail before the parts are actually joined together. roymattblack attached the following image(s):
Well that`s a top result Roy  can`t wait for more  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Nicely done Roy  some great weathering as well. Al
Many thanks guys. I'm working away on the interior of the boot still and have added the fuel pipes and breather pipe. Also now added the back wall to the boot. There's not really much else in this part of the car so now it will be working on getting the boot lid fitted. Then the body halves can be put together. roymattblack attached the following image(s):
Joined: 22/03/2016 Posts: 175 Points: 552 Location: Merseyside
As always Roy your work is top shelf stuff Built- Shelby Mustang, Lamborghini Huracan Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
Thanks for looking in Steve. I've made the air vent that is in the boot lid and it's now in place. Lots of smoothing and sanding needed and shortly the main rear halves will be joined together. roymattblack attached the following image(s):
Hi this coming along great,enjoying following .cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Many thanks Mick. The upper and lower rear body halves have now been glued together. I've added the weld seam that runs around the join on the model as it was there on almost All lightweight E Types. It wouldn't be seen on road cars as the chrome bumper fixes over it. Ok - the famous number 23 didn't have it... I know but I just like the look as it adds a little moor for the eyeballs to look at. More filling to do and then drilling the bumper fixing holes. Soon be time to fix the rear end to the main floor. roymattblack attached the following image(s):
That is looking brilliant Roy!  Top work. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Many thanks Phil. The tail end and main body are now joined using epoxy as it's a weak area of the model. The entire rear end is held on at just the two joins behind the doors at the bottom. Inner rear bulkhead next. roymattblack attached the following image(s):
Looking impressive already Roy  nicely done. Al
Excellent work Roy, it does look rather delicate at the moment. Mark Regards Markwarren (Mark) Admin
Some of the rear end flimsy has been sorted by the addition of the rear floor and bulkhead. I measured the kit part and cut it down accordingly. Once glued in place it has added extra support to the tail end. Door shut ends and inner panels have been fabricated and fitted. Filler and smoothing next... roymattblack attached the following image(s):
Coming along now, im really enjoying this one Built- Shelby Mustang, Lamborghini Huracan Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
I have added the bulkhead parts that the drop-head car has, and have also given the body a base coat of primer. This is to highlight areas that need filling and sanding. Also, the rear wheel arches need smoothing to create an even curve. roymattblack attached the following image(s):
Looks excellent, its amazing how it looks and comes together when just priming it. Mark Regards Markwarren (Mark) Admin
Roy i love how you`ve replicated the seam lines where the panels would have been welded together  great  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Great update Roy  looks sturdier at the rear now. Al
 Looking very nice now the undercoats gone on and I see you have added the spitfire flanges to the rear Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (5)
