3 Pages 123>
Sauerkraut - HM Bark Endeavour 4-pdr cannon build. Options
#1 Posted : 17 May 2018 11:06:12
Cook 250 - Endeavour cannon build competition entry.
So this cannon build is going to be called Sauerkraut. It was common for crews to name weapons, if they did or not on Endeavour i do not know but its a good bet. I have decided this cannon was named by her crew as Sauerkraut becaue it was a strange feature of Endeavours journey of discovery. Captain Cook believed that Sauerkraut was the answer to scurvy so encorae his seniors to eat it with every meal which encoraed the crew as a whole to eat it. Well we no know this to be nonsense his crews health was due to the regular stocking of fresh fruit and vegtables. But I can imagine the crew got sick of Sauerkraut LOL
The Build will start soon Cool
#2 Posted : 17 May 2018 11:36:05
Good luck Cool
#3 Posted : 17 May 2018 20:11:06
Tomick wrote:
Good luck Cool
Thank you my kit arrive today safe and sound
I am actualy away on holiday 1st of June when the build is alowed to start so i have even less time😂😂😱
usersteve83
#4 Posted : 17 May 2018 20:32:50
Good luck Jase im in on this too Confused
Built- Shelby Mustang, Lamborghini Huracan
Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
TRGRichie
#5 Posted : 17 May 2018 20:48:51
jase wrote:
Tomick wrote:
Good luck Cool
Considering your experience and past works you could go on holiday for 3 weeks and still smash this out of the part.
Best of luck.
Rich
AUTO FRUMP STOMPER
#6 Posted : 17 May 2018 23:24:26
...and to you, the more the merrier
#7 Posted : 17 May 2018 23:26:16
TRGRichie wrote:
jase wrote:
Tomick wrote:
Good luck Cool
Best of luck.
Rich
Not sure what you mean, i have never ever ever built an Endeavour cannon before Flapper
#8 Posted : 18 May 2018 07:30:02
BigGrin Good luck in the compCool
#9 Posted : 18 May 2018 07:55:37
Good luck in the competition.BigGrin
#10 Posted : 18 May 2018 10:57:52
Good luck Jase, looking forward to seeing your build.
daffy09
#11 Posted : 18 May 2018 12:13:37
Hi Jase,
I'm a little 'out of the loop' on this one and hadn't heard about this competitionConfused . I see that several members are going to have a go at it. Can you tell me more about it please. Good luck with your entry.
Happy building
David
#12 Posted : 18 May 2018 12:33:29
daffy09 wrote:
Hi Jase,
Happy building
David
here you go Daffy
http://forum.model-space...=278703&#post278703
Good luck if you decide to have a go BigGrin
Gray
#13 Posted : 18 May 2018 13:06:40
daffy09 wrote:
I'm a little 'out of the loop' on this one and hadn't heard about this competitionConfused. I see that several members are going to have a go at it. Can you tell me more about it please.
It's been on the forum since the 8th March and also noted in the competitions area of the forum..
http://forum.model-space...=273280&#post273280
#14 Posted : 18 May 2018 14:59:03
Good luck JaseBigGrin regards PhilCool
daffy09
#15 Posted : 18 May 2018 18:10:25
Thanks for all the info Tomick.
As I said, I haven't really been around on the forum lately and sadly, I must have missed this one.
I read your post on the rules of the competition and I don't think I've made enough posts this year to qualify as an entrant but I'll be more than happy just to follow the build diaries of the entrants and I wish them all good luck.
Thanks again Mr T.
Happy building
David
#16 Posted : 18 May 2018 18:59:03
daffy09 wrote:
Thanks for all the info Tomick. I read your post on the rules of the competition and I don't think I've made enough posts this year to qualify as an entrant
You’ve until the 1st June to make 25 posts which could be reached in just a few days or a week if you wish to enter Cool
#17 Posted : 19 May 2018 05:29:23
Thanks mate
daffy09
#18 Posted : 19 May 2018 14:40:32
CaptnBirdseye wrote:
daffy09 wrote:
Hi Jase,
Happy building
David
here you go Daffy
Gray
Thanks for posting the link CaptnBirdseye, good luck with your entry if you're having a go
Happy building
David
#19 Posted : 21 May 2018 11:49:06
All the best in the Cook 250 comp Jase!Cool
#20 Posted : 03 June 2018 18:52:30
Ok Got this bad boy up and running todayCool
Cannon
My first step was to chemically blacken the metal parts
whilst the chemicals are working their magic I gave both sides of the wood parts a sand with fine abrasive while still in the ply sheet.
The front Axel was removed and cleaned up first. These parts are CNC cut not laser cut so no scorch marks to remove, but wood finer left from the cutting process needs cleaning up. The two truck hubs were rounded off with a needle file first and then fine abrasive paper.
The first set of trucks where cleaned up and test fitted, I believe the trucks to be a little to thick so I have sanded mine down a bit.
With all the parts of the carriage cleaned up I did a test fit using the brass rod provided, all goodBigGrin
A 0.5mm drill bit provides a good fit for the eyebolts. The rear Axel and both sides are drilled out in the correct places for the eyebolts. I have also added larger holes for a correction to the kit parts.
Display Base
Like other I have followed the logic that the cannon looks at its best when rigged and therefore I need a section of deck.
I started by shaping the waterway plank using a shaping tool. this was then glued along a thin piece of wood sheet that will act as the substrate for the decking.
On the section I am doing there is one plank joint within the deck. I used a HB pencil for the caulking on 0.5mm for the deck.
A sigle plank was then fixed in place atop the waterway plank to form the inter bulwark. some 3x3mm strip was cut to approximate length to act as spacers for the outer bulwark planking which was then built up.
With the glue dry by lunch time I was able to saw, file and sand the bulwarks to the desired hight.. everything including the decks were then given a very fine sand.
Finally for today the ends of the display were primed down to tidy it all up and it was test fixed on the stand.
3 Pages 123>
This page was generated in 0.240 seconds.
