13 Pages «<34567>»
Anakin Skywalker's Podracer Diorama Options
#81 Posted : 12 May 2018 18:05:32
I have taken both parts of the instrument panel, where I had drilled out the holes earlier in my post and did a little bit of scratch building before spraying them. I used steel metalcote paint for the front panel and aluminium for the inner section and top plate. I then cut a piece of fine plastic card and glued three SMD’s to it. I then fed the wires through the lower instrument panel and glued it into place. The plastic card will help diffuse the light through to the top panel when fitted.
For the top panel I have printed some screen shots and as you can see in the last picture to see how they look. These were just a test fit and will be printed on high gloss card with a high resolution.
More very shortly.
#82 Posted : 12 May 2018 18:19:35
BigGrin Looking good and top workCool
godan61
#83 Posted : 12 May 2018 21:00:08
Competition Winner of Model Builds: Competition Winner of Model BuildsBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Loving this build
#84 Posted : 12 May 2018 23:50:53
Nicely done Mark BigGrin instruments will look great once lit up.
#85 Posted : 12 May 2018 23:54:30
Top quality detailing Mark, looks excellent.....Drool Drool
#86 Posted : 13 May 2018 07:34:47
Really excellent work MarkBigGrin love those weathered enginesLove Love great stuffDrool Drool regards PhilCool
#87 Posted : 13 May 2018 07:59:03
Many thanks for looking in guys, very much appreciated.
#88 Posted : 13 May 2018 14:15:12
A little more done today. I have to say, finishing this part of the cockpit definitely tested my patience. As you can see, I have placed the printed transfers into the cockpit screens. I have also placed some cables on the outer parts as per the full-size prop.
And finally, I got to test the lighting. Phew, they worked.
More soon.
#89 Posted : 13 May 2018 14:23:28
Well worth all your effort though MarkBigGrin look awesomeDrool regards PhilCool
Andreas
#90 Posted : 13 May 2018 17:31:08
Groups: registriert
That´s really great, looks awesome. Enjoying it following your Built.BigGrin
Forum Support Team
#91 Posted : 13 May 2018 20:17:16
Many thanks for your comments Phill and Andreas.
#92 Posted : 13 May 2018 20:25:06
Awesome stuff. Cool Cool Cool
Can`t wait for the next update. Drool
#93 Posted : 13 May 2018 21:49:54
Nicely done Mark BigGrin definitely worth the effort.
#94 Posted : 13 May 2018 22:59:03
looking fab looks a bit fiddly, lots of breath holding LOL
worth the effort though
#95 Posted : 14 May 2018 07:22:13
A lovely level of detail going into this Cool
#96 Posted : 14 May 2018 07:57:04
BigGrin Very nice work on the console and looking goodCool
#97 Posted : 15 May 2018 17:26:45
Hi some very nice additions being added to this ,enjoying following this cheers mick.BigGrin
#98 Posted : 15 May 2018 17:53:03
Lovely work as always mark
#99 Posted : 15 May 2018 20:35:24
Many thanks for looking in guys and all the kind comments. BigGrin
#100 Posted : 22 May 2018 12:07:54
I have started doing some detailing on the internal side panels. I was going to see whether I could put some lighting there as well, but there was no room as all the parts fit flush against the bulkhead.
The outer panels glue onto the side of the pod with holes that hold them in place. As I am having the pod in flight, I wanted to have these flaps in the open position, so I had to do a little modification. I first filled the holes on the back section and sanded off the notch on the outer panel.
The cockpit display had a little light bleed at the top, and after looking at the screen shot pictures from the film, I noticed it has an aluminium cowl over the top. I used a piece of large heat shrink tubing and cut out a piece to fit over the top. I then painted this with a silver undercoat paint, and once allowed to dry for a few days, I will give it a polished aluminium look.
The last few pictures show the pod, test fitted together. You will also notice I have painted the rim around the seating area black, something I noticed on the original prop.
More soon
13 Pages «<34567>»
