I have taken both parts of the instrument panel, where I had drilled out the holes earlier in my post and did a little bit of scratch building before spraying them. I used steel metalcote paint for the front panel and aluminium for the inner section and top plate. I then cut a piece of fine plastic card and glued three SMD’s to it. I then fed the wires through the lower instrument panel and glued it into place. The plastic card will help diffuse the light through to the top panel when fitted. For the top panel I have printed some screen shots and as you can see in the last picture to see how they look. These were just a test fit and will be printed on high gloss card with a high resolution.
More very shortly.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
 Looking good and top work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro     Groups: Registered
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Nicely done Mark  instruments will look great once lit up. Al
Top quality detailing Mark, looks excellent..... Regards Alan
Really excellent work Mark  love those weathered engines  great stuff  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Many thanks for looking in guys, very much appreciated. Mark Regards Markwarren (Mark) Admin
A little more done today. I have to say, finishing this part of the cockpit definitely tested my patience. As you can see, I have placed the printed transfers into the cockpit screens. I have also placed some cables on the outer parts as per the full-size prop. And finally, I got to test the lighting. Phew, they worked.
More soon.
Well worth all your effort though Mark  look awesome  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
That´s really great, looks awesome. Enjoying it following your Built. Forum Support Team http://www.model-space.com/de/
Many thanks for your comments Phill and Andreas. Mark Regards Markwarren (Mark) Admin
Awesome stuff. Can`t wait for the next update. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nicely done Mark  definitely worth the effort. Al
looking fab looks a bit fiddly, lots of breath holding worth the effort though Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
A lovely level of detail going into this
 Very nice work on the console and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi some very nice additions being added to this ,enjoying following this cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Lovely work as always mark
Many thanks for looking in guys and all the kind comments. Mark Regards Markwarren (Mark) Admin
I have started doing some detailing on the internal side panels. I was going to see whether I could put some lighting there as well, but there was no room as all the parts fit flush against the bulkhead. The outer panels glue onto the side of the pod with holes that hold them in place. As I am having the pod in flight, I wanted to have these flaps in the open position, so I had to do a little modification. I first filled the holes on the back section and sanded off the notch on the outer panel. The cockpit display had a little light bleed at the top, and after looking at the screen shot pictures from the film, I noticed it has an aluminium cowl over the top. I used a piece of large heat shrink tubing and cut out a piece to fit over the top. I then painted this with a silver undercoat paint, and once allowed to dry for a few days, I will give it a polished aluminium look. The last few pictures show the pod, test fitted together. You will also notice I have painted the rim around the seating area black, something I noticed on the original prop.
More soon
