29 Stern Frame Options
Rabbit6
#1 Posted : 06 May 2018 12:14:55
Rank: Beginner Level 3
Hi
I've pushed the stern frame (29) as far as it will go onto the keel but it doesn't sit flush like all the other ribs do - it oversits by about 3mm. Is this correct or do I need to file down the slot so that it will sit flush?
#2 Posted : 06 May 2018 14:12:35
Hi there, the frame needs to be level with the keel otherwise you'll run into problems when fitting the deck and dummy gun supports....Cool Cool
Rabbit6
#3 Posted : 06 May 2018 14:40:01
Excellent, thanks. I shall sand the slot to make it fit.
