10 Pages «<23456>»
ORP Błyskawica ship diorama. Options
#61 Posted : 03 May 2018 20:51:36
This is a lovely kit, very well put together. Very impressive.Love
#62 Posted : 04 May 2018 06:01:18
love the deck plating and the etch bridge this kit is turning out to be something a bit special
nice build Andy
#63 Posted : 04 May 2018 07:17:17
#64 Posted : 04 May 2018 08:16:44
Looks great Andy.....Cool Cool
#65 Posted : 04 May 2018 09:22:46
Looking very nice Andy and some high quality etch provided around the superstructure by the look of it too.
Well done. Cool ThumpUp
#66 Posted : 04 May 2018 09:23:58
The etch looks perfectBigGrin was it easy to bend i no some older etch is a little thick Confused looks like a great kit so far AndyDrool Drool regards PhilCool
greyhawk
#67 Posted : 04 May 2018 09:55:04
#68 Posted : 04 May 2018 11:02:14
Looking great Andy, you must be working 24/7 on this.
arek
#69 Posted : 04 May 2018 12:16:24
looking great!Cool lovely details on the bridge carcase!
regards,
Arek
#70 Posted : 04 May 2018 17:05:06
BigGrin Thanks for looking in and your comments everyone.
The etch provided is fine and of different thicknesses the side wall plates being the thickest then thinner again for medium bends and even thinner for the rounded front of the bridge.
I mostly work from home these days so have lots of time to complete both work and other commitments.
#71 Posted : 04 May 2018 17:10:40
BigGrin Hi all
The bridge doors, downpipes, trunking, brackets and rails have all been added to the sides. After that the upper bridge splinter deflectors were added to the upper front bridge and sides and the mid height splinter deflectors added to the forward bulkheads.
More soon.
#72 Posted : 05 May 2018 19:37:09
Hi looking really nice,like the brass work .cheers mick.BigGrin
#73 Posted : 05 May 2018 19:56:26
A good clean build on the superstructure AndyBigGrin nicely done.
#74 Posted : 06 May 2018 17:59:00
#75 Posted : 06 May 2018 18:04:10
BigGrin Hi all
After the hull paint cured inspection found still a lot to do so it was out with more filler and then another sanding back. I have also drilled out the port holes using the templates provided and filled the drill holes with pre-cut 5mm x 2mm brass tube included in the kit.
More soon.
#76 Posted : 08 May 2018 18:12:26
BigGrin Hi all
The hull has had the bilge keels fitted along with the rubbing strips and some etch covers added. Next its more deck furniture starting with the central deck spine made up from wood and ply then covered top and sides with the deck plates. The nest item was the funnel base lots more etch added here along with lots of doors and wheels.
The next thing to be built is the rear gun station the carcase has been made up and the brass started to be added the top deck has been covered in plates.
More soon.
#77 Posted : 08 May 2018 20:22:53
Great update AndyDrool Drool looks a real nice kitBigGrin regards PhilCool
#78 Posted : 08 May 2018 20:32:18
Coming along at a rate of knots now Andy BigGrin nice going.
#79 Posted : 08 May 2018 21:02:07
It's really starting to take shape, looking good.
#80 Posted : 08 May 2018 21:48:42
Great work Andy.Love I just love the detail and quality of this kit, and you are making it look so easy.Drool Drool Love Love
Guest (7)
10 Pages «<23456>»
This page was generated in 0.227 seconds.
