And so we go on..
Pack 9
Pack 9 sees Pod 4 taking shape.
The rear wall and door are assembled and fitted and should be painted and weathered to match the front wall and hatch.
The upper gantry walkways are assembled and fitted here, as is one inner wall panel. All of these parts are painted and weathered in the same way as the first pod some time ago.
The Domo is quite a complex kit and has a lot of parts.
Particular care should be taken when clipping the three arms into place on the main body as they are a tight fit and the locating pins could be broken.
The Domo is weathered using thin washes of matt black and brown. The washes can be made using white spirit or water, depending on the types of paints you are using.roymattblack attached the following image(s):
