Modifying stain color on porous deck wood Options
m0325
#1 Posted : 02 May 2018 18:17:35
Any suggestions for lightening acrylic wood stain on top deck.
#2 Posted : 02 May 2018 18:42:19
Hi m0325
You could try using acrylic artists inks, put a coat of light yellow or grey on 1st to lighten the dark stain then put a lighter mix of light and dark browns or even a lighter stain.
m0325
#3 Posted : 03 May 2018 14:50:58
Thanks for the advice. Sounds complicated. Is there a reasonably safe way to remove then stain and start over?
#4 Posted : 03 May 2018 17:25:41
You could remove the old planking if you have used a PVA glue by soaking it with warm water and then lifting it off after the glue softens. Another way would be to just plank over the existing deck with fresh planking but bear in mind the cannons heights will need adjusting to fit the gun ports.
m0325
#5 Posted : 03 May 2018 20:24:28
Thanks for your help.
This page was generated in 0.137 seconds.
