6 Pages «<3456>
Artoo Detoo, you know better than to trust a strange computer Options
semaj
#81 Posted : 25 March 2018 16:01:13
next up we have a bit more progression on the leg, almost completing it, barring a few screw plugs left to add later in the future. we also got some more dome panels, which will all be fitted in the next update.
semaj attached the following image(s):
Building:
Complete:
semaj
#82 Posted : 25 March 2018 16:10:35
final update for now, and this is a BIG one!!
issue 62-65 sees us bring the entire dome together, fixing the dome with all ts panels onto the framework, along with most of the lcd screens and lights that we have assembled to date. i laid out all the parts that are about to be fitted over the next several images. this was an awesome afternoon of building.
as i mentioned earlier i left all the panels in previous issues to assemble them all in one go, so i shall now add them here. this includes a hinged flap at the top of the dome where the light saber pops up from.
we also added a few brackets inside the dome framework to enable us to mount the camera and projector at a later date, along with a few cable tidy clips.
i must say, the almost finished dome looks stunning!
all this will be covered over the next few posts as i took so many images, and didnt fully follow the sequence in the magazine. so i shall break it down into sections
Building:
Complete:
semaj
#83 Posted : 25 March 2018 16:33:54
so here is fitting all the panels to the dome shell. you really see it come together!
Building:
Complete:
semaj
#84 Posted : 25 March 2018 16:40:12
so there we have all the panels now attached to the dome! looks fab, and took a good hour and half. them strips of tape were fiddly to get in place. (note the very top circular panel is only temporary fitted at this point)
next up i turned my attention to the framework. we need to add a couple more brackets for the camera and projector to be mounted to. i also built up and added a hinged flap to the frame where the light saber will pop up from.
Building:
Complete:
semaj
#85 Posted : 25 March 2018 16:47:54
now i was ready to attach the completed dome to the framework. we fit the speaker which was built up previously, fit the dome over, lining up the key way up on the dome to the frame. the circular top panel is then fitted in position. we turn it over, fit some spacers over the pegs and screw down. this permanently locks the dome to the frame. afterwards we start adding some locking screws to the sides to add extra stability to the panels.
its really starting to gain some weight now, and feels nice and solid too. very happy with how its looking.
Building:
Complete:
semaj
#86 Posted : 25 March 2018 16:59:44
finally once the dome was all secure, it was time to start adding all the electrics that have been built up previously - all the lights, lcd screens etc. i also added some cable tidy clips. this brings the dome to around 85% completion. all that is left (that i can see) is the projector and light saber tube to be fitted, a few more electrics and maybe the rotating mechanism?
the finished dome looks stunning, the pictures just dont do it any justice at all. cant wait to get it connected to the body and all lit up!
Building:
Complete:
semaj
#87 Posted : 25 March 2018 17:04:48
sadly, i need to re order issue 65 do to having a part that looks rather faulty. the diffuser for the rear orange/green light looks some how like its been against something hot and melted. its out of shape, warped, does not fit and looks terrible. these things happen though. i temporarily fitted it as best as i could just to see how the finished dome looked.
Building:
Complete:
semaj
#88 Posted : 30 April 2018 22:44:53
another month, and another delivery arrives!
firstly, just to update on the problem i had with issue. i called de agostini ordered a replacement which arrived after 2 weeks. so all happy with that now.
onward with the next set of mags issue 66, 67, 68 and 69.
with issue 66 we added a few more screws into the framework of the dome, fitted the projector and a distribution board that all the electrics will plug into later in the build. that pretty much completes the dome now, with only a few bits left to add, namely the light saber ejection tube which will be added later. its got quite a bit of weight to it, and feels really sturdy and strong. lots of engineering has gone into the design that's for sure!
the next 3 issues take on a change of direction as we now head on with the body! starting with more heavy duty metal framework and making a start on the first of many body panels. a few detail parts are screwed into place. i keep saying this but i'm really impressed with the the overall quality of parts, and everything fits perfect!
so that completes the build for now, everything is neatly stored in a box which is getting really heavy now, with 2 complete legs, 95% complete dome and the beginnings of the main body.
Building:
Complete:
semaj
#89 Posted : 30 April 2018 22:59:49
and yes, i noticed in issue 67 i have screwed the metal plates on the brackets the wrong way around. this has been corrected since the photos were taken.
Building:
Complete:
#90 Posted : 01 May 2018 06:58:17
BigGrin Looking good and coming together nicelyCool
semaj
#91 Posted : 26 May 2018 22:48:34
As May shows itself to be a great month, 4th May was international star wars day, the recent release of the new film Solo and of course another R2D2 delivery is upon us!!
Here is issue 70 - 73 inclusive. This time R2 begins to find his voice with the addition of a speaker along with another body panel and more work on the framework for the main body. Not masses or work but great progress!
I had a few issues with this delivery as can be seen in my images, mainly regarding the body panels, firstly there is a slight mis match in colour - the 2 panels i have are different shades, there is also a slight mis match with the size of them too. For me there are both pretty minor points and kind of adds to the quirkiness of the droid (i also have a 2 tone foot on 1 leg, and the powerbus cables are different colours on each side as 1 set are bright another set is dull), after all the movie props were never perfect either and i do plan to add a bit of weathering once complete.
Another problem i had, which was of a bit more concern was with issue 73, we are supplied 4 rods that are drilled and tapped at each end so we can bolt them to the frames. The magazine asks us to use 8mm long screws to attach them, which was fine for 3 of my rods, but 1 rod the 8mm screws didn't screw all the way in and left the pole very loose (as can be seen in the pics). It was the same at both ends. I came to the conclusion that it hadnt been drilled or tapped deep enough. So in the long run i decided to simply file down one of the screws to fit - in the end i had to remove a whole 2mm, so it is now fixed with a 6mm screw! I dont think this will pose much of a problem as i have been using threadlock on all the frame parts anyway. Everything still feels pretty good and solid so problem solved.
Building:
Complete:
#92 Posted : 27 May 2018 07:28:36
BigGrin Looking good that frame when complete has a good weight to it and is very sturdyCool
#93 Posted : 27 May 2018 07:39:11
Nice update, he is going to be some weight when finished.Cool
#94 Posted : 27 May 2018 10:00:49
Good to see your progress which looks impressive
semaj
#95 Posted : 14 July 2018 23:55:17
realized i haven't updated this blog for 2 months, so here we go.
1st up is last months delivery consisting of issue 74, 75, 76 and 77.
we build up the rest of the rear body panels, add more to the frame work, and finalise the dome by tidying up the wires and plugging them all in and finishing the light saber tube and fitting it in place too, this was super fiddly but i got there in the end. really enjoyable chunk of building, and can really feel the pace picking up now!
Building:
Complete:
#96 Posted : 15 July 2018 00:06:28
BigGrin Looking good and its starting to all come together very nicelyCool
semaj
#97 Posted : 15 July 2018 00:09:14
Another month comes along, and so does the postman with the latest R2 delivery!
As before the pace feels like its really picking up with lots to do, i thoroughly enjoyed the build today. I keep saying it, but the quality and fit of the parts is second to none. Truly superb.
This month we again add a few more parts to the framework for the body which is nearing completion. R2 also gains a set of arms, in the form of some of the manipulators in a compartment fitted to one of the front body panels. This includes our 1st proper sets of sprues of parts, making it feel more like a proper model kit. The sprues are typical black plastic that has been painted either gold or silver, they cleaned up nicely and fitted into position perfectly with a spot of glue. The door also has a nice feel to it with how it 'clicks' into place, along this the arms that are manually hinged out, they have a nice 'ratchet' feel to them so they hold in any position you like and not loosely drop out. This is all really well thought out. We also make a start on the complicated front panel that will be built over a few issues.
Cant wait to get this finished now and see all the parts come together!
Building:
Complete:
semaj
#98 Posted : 15 July 2018 00:14:44
It came to my attention that there was an error in the magazine, and one of the manipulator, namely the upper fine manipulator arm fitted in issue 78, is incorrectly fitted upside down.
Thankfuly it is a super simple fix, just simply unscrew it, flip it around and screw back in.
Building:
Complete:
#99 Posted : 15 July 2018 00:25:38
All looking good and on the home stretch with 80 issues complete.
Cool Cool Cool
#100 Posted : 15 July 2018 09:42:20
Looking very good, a few more compartments on the front to do.BigGrin
6 Pages «<3456>
This page was generated in 0.514 seconds.
