 Rank: Beginner Level 1  Groups: Registered
Joined: 02/01/2017 Posts: 6 Points: 18 Location: U.K.
Hi guys, my first post, just a question regarding the flaps on the body, in the discription it says > “The flaps on his body conceal hidden droid manipulator arms and probes, which you can extend at will.“ Does this mean it’s controlled from the app  or do you have to manually open them Seàn
Hi Sean7r The left side toolbox fitted in Issue #78 is a manual operation only feature. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 19/01/2017 Posts: 64 Points: 216 Location: UK
"by will" , in this case means , any time you wish by the aid of your own finger (other body parts are also available !) SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
