4 Pages 123>»
Silent_Running Victory Build Log Options
Silent_Running
#1 Posted : 17 June 2011 22:46:25
Hi shipmates,
Well, here is the start of my build log for HMS Victory. Any hints, tips or pearls of wisdom are greatly appreciated. All are welcome here! Hope you like?
Silent_Running
#2 Posted : 17 June 2011 22:54:20
Text and pictures to follow shortly, I'm doing it now LOL
#3 Posted : 18 June 2011 00:16:44
Welcome aboard silent_running.
Regards tf64.
Silent_Running
#4 Posted : 18 June 2011 00:24:26
Thanks tf64 for the welcome BigGrin
Silent_Running
#5 Posted : 18 June 2011 01:08:18
Hi shipmates,
As you can see the bow formers went together really well. After a very light sanding, just to make sure that there were no rough edges, everything went by the numbers if you'll pardon the pun. I did have bit of a scare a bit later on because I had not used a set square to make sure the formers were at a perfect right angle. Talk about a newbie mistake Blushing. It all turned out alight in the end though phew!!! They were dead on thank goodness!
I intend to add balsa fillets a bit later on, before I start the planking. I noticed that some of you guys are doing it and I think its a good idea, and also I think it will add a larger surface area to glue the planking strips on. I'm going to use PVA glue to fix the planking strips and not contact adhesive, because I have decided to paint Victory in the Trafalgar finish. So any residual glue marks will not be noticed, after the sanding and paint has been applied.
I have another HMS Victory in the pipeline with a natural finish, so will have to reconsider my options for that one. I also have two other Victory hulls ready laid but not planked, making a grand total of four in total more on the other three later.
Just had a look at the photo and noticed two things 1. the two bow formers on ether side of the central one look a bit squint at the top, is this normal? A natural curve or do I need to adjust them. 2. I have set the photo size to 640 x 480 in Photobucket is this too large or do I need to reduce the size further before my next post? I would appreciate any advice you might have?
Kind Regards
z8000783
#6 Posted : 18 June 2011 07:53:22
Groups: Unapproved
Hi Glen
Good to meet you.
Don't worry, there are a couple of fillets that go in that space when you get to Issue 20, which should straighten it up.
Yes the pics are wide, I usually use 670 and they fit perfectly. Strange, 640 should be OK. Have a look here (last one).
Your picture downloads at 1024 which I guess was your original size, are you sure the settings in photobucket are set correctly?
John
Gerrit
#7 Posted : 18 June 2011 08:24:14
Welcome Hope you enjoy it as much as I do. Feel free to ask questions and take any advice from these experienced crew man on this forum.
#8 Posted : 18 June 2011 09:29:01
Welcome aboard Glen, looking good so far!BigGrin
Silent_Running
#9 Posted : 18 June 2011 10:36:55
Hi John,
Thanks for the info on the fillets, and the welcome BigGrin looks like I was worrying about nothing. About the photo, I think your right on that one. I will re-check the settings. I had a gut feeling it was wrong when I posted it LOL I will resize and re-post this pic me thinks. Nice to meet you too as well.
Silent_Running
#10 Posted : 18 June 2011 10:53:41
Hi Gerrit,
Thanks for the welcome, and yes I'm really enjoying it. There is a real sense of community here and lots of support, plus banter thrown in which is great. BigGrin You are so right about the crew in this forum. As I said on another post there are some really talented model makers and craftsmen here. I will be asking questions, lots of them. LOL. I'll have a look at your build diary as well. I haven't had the chance to have a look yet. Good to meet you and stay in touch. BigGrin.
Silent_Running
#11 Posted : 18 June 2011 11:09:42
Hi MWG,
Thanks for the welcome and the compliment. I'm way behind the rest of you guys regarding the build. That's a good thing for me though I think! It gives me a chance to have a look at other peoples build diaries, and also to take note of any issues they might have had. One of the biggest things though is that it gives me inspiration for my own model. Another thing I quickly realised is that everyone has their own style of building. No two people approach building say HMS Victory in the same way, even though they are building the same model. It has become a source of fascination for me, or am I just a bit sad? Wouldn't be the first time LOL
z8000783
#12 Posted : 18 June 2011 11:19:19
Groups: Unapproved
LOL Not sad at all.
The thing is there is no correct Victory. The one that was built is very
different to the one at Trafalgar which is nothing like the one now at
Portsmouth.
I am trying to make mine authentic but I often can't find the answer so
who's to say I'm wrong.
Like you I am way behind which is exactly where I want to be and enjoying
every minute of it, apart from the (insert F word here in it's imperfect
form) stern planking.
John
#13 Posted : 18 June 2011 12:04:54
Quite true John, full accuracy for each period of Victory's life simply does not exist, where the main period's depicted for models are 1765, 1805 Trafalgar and current day, all three guises are very different, where to some extent accurate info for what actually was is ongoing research.
A very good example being the Prince of Wales plume of feather's which adorm's the taff rail at the stern, this did not in fact appear on Victory until 1837, and was salvaged from another ship (HMS Prince also at Trafalgar), yet all kits represent the 1805 Trafalgar Victory as having the plume of feathers, which has been adopted from how Victory is seen today, yet is totally incorrect for the 1805 Victory.
What was actually in place is still to be confirmed, and may never be confirmed, but it has been narrowed down, and thought to have been either King George III's coat of Arms or a medallion featuring a bust of the King.
Basically, todays Trafalgar guise Victory differs in many ways to that seen in 1805.
By the way welcome to the forum Silent Cool
Silent_Running
#14 Posted : 18 June 2011 12:58:17
z8000783 wrote:
LOL Not sad at all.
Portsmouth.
John
Hi John,
Yes Victory is very different now. One might wonder what Nelson would have made of her now, especially with the health and safety measures now in place. That would have made him cough on his wine BigGrin Although the restoration was necessary otherwise we would have lost her, it just shows how bad a condition she was in. It required decades of work to put her right. And its still ongoing.
As with any naval re-fit, the shipwrights had different ideas available to them at the time and as new research became available. Thus as Tomick said, the original character of the ship is lost as time progresses.
I think the Victory of today is forever a museum piece. She is so far removed now from being a seaworthy vessel, I don't think she could ever be re-floated she's just too fragile. What do you think? If you wanted a seagoing Victory now, you would have to build a brand new copy of her. As they have done with Endeavour and HMS Surprise, at least that's my opinion. And planking, yes, really looking forward to that. I'm busy steeling myself for the highs and the lows Lol.
z8000783
#15 Posted : 18 June 2011 13:07:23
Groups: Unapproved
Considering the defence cuts and the fact she is still a commissioned ship
she could well find herself putting to sea again if needed.
John
Silent_Running
#16 Posted : 18 June 2011 13:33:33
You're so right there John, if we have to defend the Falkland islands again at this rate, our proud navy will be setting off to battle in Tongan war canoes!!
Silent_Running
#17 Posted : 18 June 2011 13:35:17
Hi Tomick,
Thanks for the welcome, pleased to meet you. What you said about different Victory's, reminded me about an article that I read regarding the fate of the fourth version of Victory. She was shipwrecked and sank due to her high sides and narrow draught. As you will already know, whilst the narrow draught was great for speed it led to problems when manoeuvring, and the high sides of the fourth Victory meant that in gale force winds she couldn't tack to get her out of difficulty.
It made me think that perhaps the design flaws of the Galleon influence took a long time to be purged from warship design, and that ship designers were heavily reliant on it. Perhaps the design of Nelsons Victory, marked a radical departure in design for a first rate. What do you think?
Glen
#18 Posted : 18 June 2011 14:44:36
From one Glen to another Glenn welcomeBigGrin
Roger the Cabin Boy
Silent_Running
#19 Posted : 18 June 2011 14:57:06
Hello Glen,
Nice to meet you, us Glens do get around a bit BigGrin
Hans
#20 Posted : 20 June 2011 15:16:36
Hi Glenn and welcome. If you want to know something, this is the place to seek and find. It not race, so sit back relax and enjoy the ride, because its one hellava painful and suffering ride!! but oh the satisfaction of a job well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Guest (5)
4 Pages 123>»
This page was generated in 0.171 seconds.
