newbie after advice please. Carbon graphics Options
scottww86
#1 Posted : 17 June 2011 21:50:12
hi guys. ive always had nitro R/C car models but as soon as i saw this kit i just had to have it!!
i was going to just build the kit "out of the box" but saw some guys had gone with the carbon fibre water slide decals and again...........i just had to have it!! BigGrin
as i say its my first time using these and i found them a bit tricky but managed a pretty good result i think. (hopefully get pics up soon!). before i do ive noticed people mentioning the tamiya clear smoke. is this just for use with an airbrush or is it available in tins?
im using the scale motorsport 1/12th decals and would like to tame the look down a bit if possible.
any tips would be grateful for water slide decals! LOL
thanks
scott
#2 Posted : 18 June 2011 22:08:32
Hi Scott and welcome to the forum.. The tamiya clear smoke is available in either a bottle (all Tamiya paints come this way) or in a small spay can.. If you have used spray cans before which I am sure you have with your RC cars then thats the best way.. just use plenty of ventilation and lights coats.. either that or brush on but i find the paint drags..
Spencer
#3 Posted : 18 June 2011 22:21:51
Don't get too carried away with your 1/12 scale decals, because this model is 1/8 scale Wink
scottww86
#4 Posted : 19 June 2011 00:20:05
oh yeah!!! cant beleive i didnt realise! lol.
cheers for that spencer, ill look in to getting a spray can from somewhere. can you recommend anywhere to buy from?
scott
Austin
#5 Posted : 19 June 2011 00:27:58
Big T is right, I think you can easily over do certain parts of a model with the wrong materials. Carbon fiber really is subtle until you get up close so the decals that are a bit loud just don't look realistic. As big T said 1:12 to 1:8 don't really go.Huh
scottww86
#6 Posted : 19 June 2011 00:31:26
i agrre with ya that if they too "loud" it just looks daft. im going to get some of the clear smoke and hopefully tone the effect down a bit.
scottww86
#7 Posted : 19 June 2011 00:43:01
this is what ive managed so far. hopefully the clear smoke on top will soften the decals!
hoping to do each side of the upper suspension parts in 1 piece but its going to be pretty tricky!
Austin
#8 Posted : 19 June 2011 10:24:21
Well Scott for your first attempt that is a supreme effort, really well done. Like you said defo need toning down but great job.
scottww86
#9 Posted : 19 June 2011 12:28:59
cheers!! ill keep putting pics up as i crack on with it.
SennaMentalMe
#10 Posted : 19 June 2011 12:57:51
BigGrin Hi Scott, excellent result with the carbon fibre decal!! Hard to believe that this is your first attempt at using it?? I agree with you that you need to tone it down a bit, but once you have applied the 'Clear Smoke' I think it will look absolutely stunning, so please post up a pic or two after you've done that for all to see as I think a lot of us would be interested to have a look at the result!! Also, I wouldn't worry too much about doing the upper suspension arms in one piece, because if you look closely at the real thing on an F1 car, it is usually made from several pieces of carbon fibre cloth that lay up in different directions depending on where the strength is needed, so maybe it would look more realistic by NOT being done in one piece methinks?? Just a thought??
P.S. - Remember Mr. T's sound advice about not overdoing the amount of carbon fibre decal applied, as it is in the wrong scale after all is said and done, so I think a bit of subtle use here and there in key areas would look much better than having it everwhere?? Just a thought again and you know Mr.T is usually right, but well done on what you have so far, it looks nice!!
ThumpUp ThumpUp
_______________________________________________________________________________________________________________
Regards ... Kev BigGrin
Austin
#11 Posted : 19 June 2011 18:44:26
Thought you guys in barrow just made submarines?
scottww86
#12 Posted : 20 June 2011 14:50:53
and artillery and every now and again theres a late, poor build of a ship! lol
Laugh
scottww86
#13 Posted : 21 June 2011 16:26:56
do you guys know where is best to get the clear smoke from in spray form?? cant seem to find it anywhere Confused
#14 Posted : 21 June 2011 16:45:22
http://cgi.ebay.co.uk/TA...amp;hash=item43a615842f
Though unsure if the ref is clear smoke
scottww86
#15 Posted : 22 June 2011 15:16:00
thanks mr T! the ref ts-71 rings a bell with something i saw in another post. ill get it ordered!! LOL
#16 Posted : 22 June 2011 16:41:49
Check that its clear smoke before you buy Wink
dvb247
#17 Posted : 14 August 2011 10:40:10
Rank: Beginner Level 3
I just look at your pictures and I'm stunned at the level of detail you guys are going with this build, looks bloody good so hats off to you, this is a stupid question but what is the basic process to make the parts carbon look? is it a transfer laid over the part with holes in so you can spray paint it? if so I assume you then remove the transfer and clear coat it afterwards??Confused
PS where are Warthog's carbon pictures?
scottww86
#18 Posted : 14 August 2011 10:54:17
Hi mate. The decals are just like the decals used to put the the missing parts of the sponsor logo on the front wing. It's a very thin film that is stuck to the surface. The decal I used here wasn't the best but other decals like the ones warthog used look much better and don't need "tinting" to tone the effect down.
Warthogs pics are under his build diary "3x mp4-23". Not only has he bought all the decals in the bloody country he even buying three models!! LOL
dvb247
#19 Posted : 14 August 2011 10:58:08
Thanks Scott, just been reading a bit more on the forum here, I don't think I'm capable of doing this but I am pleased with the bits I've done so far on the buildBigGrin
scottww86
#20 Posted : 14 August 2011 11:34:30
its a little bit tricky but the end result is worth it i think. i thought id give it a go because "i had to have that look!" lol. glad i did! will post more pics this aft of some other bits ive done.
This page was generated in 0.202 seconds.
