 Rank: Pro  Groups: Registered
Joined: 31/03/2010 Posts: 194 Points: 446 Location: Gloucestershire
Hi all, While buying paint from my local model shop i came across a tin of sanding solution, but they was no directions or what it is used for. Can anyone tell me please? Thanks, Glen Roger the Cabin Boy
'Liquid Sandpaper' as it is more commonly known, is a chemical solution that removes the thin top layers of the surface of a glossy painted surface. As you wipe it around it matt's the glossy surface, making it easier to be repainted without having to be sanded down, and is great for keying a glossy surface.
It does not actually do any sanding and only remove's the gloss from a painted surface, and if the surface has bumps or imperfections it will not smooth these. Its more of a de-glosser, and an advantage is that because it is a solution, sanding dust is not created, which for such as lead paint its a health and saftey feature, though the clean-up afterwards can be messy resulting in additional work.
I've used it in the past on such as a fibreglass fus.
Thank you Holy One Don't think i shall bother with it Roger the Cabin Boy
