4 Pages «<234
lighting up the victory Options
RussG
#61 Posted : 09 April 2010 10:04:00
Allan wrote:
Thanks for that Russ
Question= if one led fails do they all go out if so is there away round this as its not going to be that easy to get at them once the build is finished Blink Blink Blink also you have shown a 7 led circuit do we just add as needed or will this affect the voltage?
Regards Allan
No Allan, if you do it that way then if one fails the rest still light, they will only fail if you run them in series to one another, in basics you are creating a power ring like you would have in your house then you plug each LED in individualy and a 12vdc 2W hard drive power supply is enough to run upto 150 standard LEDs as with ease as they only use 20mA each. Lets get Technical !!!BigGrin
EDITED - SEE NEW POST IT'S A BIT SIMPLER!!
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
tom.ganc
#62 Posted : 09 April 2010 10:29:08
Hi there
I'm little confused about one thing. You've said that led drops voltage by 2.3V and you will heve 11.5V left for the resistor? Things don't add up here I think. It should be 9.7V and this will calculate resistance to 485Ohm.
There is another option. Instead having to add one resistor per LED you can do it diferent way.
As you said voltage drop on led is in average 2.5V. If you want to light op larger area you need more than one led and there is a trick. You need to connect four led's in serial and this will give you 10V drop in total and all you need is add resistor for remaning 2V (if you lucky enough to find LED's with voltage drop of 2.4V and if you use 5 of them you don't need resistor at all).
This option saves some time in soldering all the resistors to led's.
I hope it helps.
RussG
#63 Posted : 09 April 2010 11:32:14
your right Tom, brain not in gear, started new topic - Circuitry 101: How to Hook Up LEDs , makes life a bit simpler.
Russ
mttmwilson
#64 Posted : 09 April 2010 14:05:09
Rank: Amateur level 2
Hi,
Thought I would post some photos of an Enterprise model I've made in the past with some lighting. This is turned on/off by remote control and can change between red/white (Night light/Normal). Bought the remote module from maplins I think. Can't remember how I wired it up but it looks awesome in the dark.
I had some problems getting decent pictures due to bright light coming through the curtains, but I think you will get the idea!!!
Built:McLaren MP4-23
Ongoing:HMS Victory, Victory Cross-Section, Harley Fatboy, Hatchette Lancaster, Flying Scotsman, Stagecoach
Mald
#65 Posted : 09 April 2010 23:50:16
I like the idea of putting lights in the lanterns on the stern of the ship , Have to wait and see how big these lanterns actually are first , Then decide if i have to remake them and install leds .
viperek
#66 Posted : 01 July 2010 20:18:23
im well up 4 it guys. I think what we need is Bi-colour LEDs yellow or orange. that way we can get candle effect. Also i would leave plenty of wire in each gun compartment so u can pull it out wit tweezers and change LED if it blows
budgie
#67 Posted : 01 July 2010 20:26:43
BigGrin interested on how u go about it keep us posted pitfalls as well
Cool if u want a dimmer light ie candle not 100watt light bulb would a resistor in the circuit produce a lower luminance????
#68 Posted : 01 July 2010 23:09:59
You can wire a group of 4/5 LEDs in series, but it's not common practice (in the world of electronics anyway.) The reasons being that you can't guarantee that all the LEDs will be the same brightness (they usually are, but not always.) and, more importantly, if you have a failure it will kill all 4 or 5 LEDs. Wiring one resistor to each LED is the usual way of doing things. That way you should only lose one LED if an LED or resistor fails, as Russ mentioned. Resistors are only a fraction of a penny each (I think I paid 50p for a pack of 100).
Heat is unlikely to be an issue if you've only got a few LED's, but best not to group all the resistors together. Assuming a 20mA current, the heat generated is around 190 mW which is pretty small and shouldn't cause a problem if the resistors are spaced apart a bit.
A bigger resistor will give a dimmer light. Also, the resistor will generate less heat as a trivial side effect.
Cheers
RussG
#69 Posted : 01 July 2010 23:19:26
tom.ganc wrote:
Hi again.
If you want to buy led's go to www.component-shop.co.uk
They are much cheaper than maplins.
I buy all led's, batterys and chargers there.
I agree with tom, I get mine from there as well as Ebay, Cant beat the chinese for LED's plus they usually suplly FREE Resistors as well !
More info on LED lighting here -> http://forum.model-space...t.aspx?g=posts&t=319
viperek
#70 Posted : 06 July 2010 21:03:38
Do You have to run it from the battery or can You run it of the AC ?? Cheers
budgie
#71 Posted : 06 July 2010 22:23:46
BigGrin BigGrin what or should i say watt 240vacFlapper
LOL what size generators are in the victory's engine roomLOL
sorry mate bit cheeky
take it u mean an ac to dc adaptor
another thought might be a pot (variable resistor)so u can alter the brightness
i know if leds are wired in series if 1 goes they all go
what about wiring in parrallel that might also keep the brightness down
Lonestar Spirit
#72 Posted : 07 July 2010 11:06:17
Can't you buy Dolls house flikering candle LED's or won't you get a realistic effect?
Ship Builds on the go
budgie
#73 Posted : 07 July 2010 21:39:38
BigGrin Hi Vipertek been thinking bout your project
1st thing i think u will need to work out is where u want ure LEDs
but the problem rises in gaining access to them & battery, remote rx to complete cct for switching them on/off or wiring
taking the complete deck off with the amount of rigging at upper deck level could mean u breaking something lots of small bits n bobs
but if u did go that way it might be best if u made the upper part seperable further down in line with a row of planking to hide the join this would help to hide ure seperation line
dont think there will be much scope for having several access points on deck without disrupting the flow of planking & taking the look of the model away
(join lines slightly higher than surrounding deck etc)
or u could gain access from the hull side (side nobody sees)using a jigsaw pattern in line with planking to keep the join line to a minimum
either way i think uve got a job & a half on ure hands
good luck let us know how it goes
viperek
#74 Posted : 08 July 2010 15:23:34
I was more thinking of pulling + and - cables out of the hull somwhere down the bottom near the stand where You wont see it at all. The LEDs in gun points are goint have to be loose enough to be able to pull them out if the LED blows the only problem i got at the moment is the lights in the captains cabin.
1. I dont know if we going to have a glass o plastic widnows.
2. It has to open somehow to be able to get the LED out.
willie
#75 Posted : 08 July 2010 17:33:52
glass windows what next
Glen
#76 Posted : 08 July 2010 17:47:02
Hi All,
If things don't start to go right i will set fire to it, that will light it up Ha
GlenAngry BigGrin Flapper
Roger the Cabin Boy
4 Pages «<234
This page was generated in 0.361 seconds.
